juan214
Engine Timing Crankshaft Gear
The timing component process is below and came before this step. The Engine Timing Crankshaft Gear did not want to come off by hand. I took my 27mm open wrench and use used to pry it away from the oil pump. Facing the oil pump there is a notch on the top left this where I inserted the wrench. It slid out with no real effort. Oil just seeped in and dried up from the heat. The damaged teeth are not from taking the gear off.
