Code:
Question.... does the Expy have to be built in Canada or just DESTINED for the Canadian market at time of manufacture?
Any Expedition that was destined for delivery in Canada, no matter whether built in Canada or USA, was equipped with the DRL feature, it was required by law at the time in Canada. (So you question was relevant, I was cavalier in my language before.)
But not a lot of the Canadian delivered (destined for) units end up back in the USA, the rare occasional ones do, usually near the border.
I found this picture all three parts (2 sort-of)
It shows, at left: The dummy loopback plug that is present on USA models at C214 under the oval dash plastic, instead of the DRL relay box, that Canadian models have (middle). The right hand side piece is the DRL resistor (the white part, and the black connector at, plugged into the connector harness (from the engine wiring harness), all encased in the DRL resistor mounting bracket. The DRL resistor mounting bracket is ALSO missing on USA models. But on Canadian models that bracket is mount behind the front bumper, in front of the driver's side front tire (on the other side of the wheel well liner plastic than the tire is on, on the truck-colored painted frame "wall" opposite the bumper, and mounted. In the earlier post on this thread, the picture with the BLUE ARROW shows the location on the frame wall opposite the bumper, as you stare up at it from below. (That is how you get at it also, from below). The white part (the resistor) is ceramic, with a black plastic male (or female, opposite whatever the wiring harness is) connector embedded in it. The wire harness plugs onto that. The resiter sits in the retaining bracket. The retaining bracket is ******* into that frame wall at that location. Not sure how the resistor stays in the bracket (may just rest there, held be spring tension, there may be a retension bolt). My USA version does not have the bracket, the wire-harness connection, or the resistor itself. The Relay box cannot be had in the USA. But I think they are quite common in Canadian yards, because all Canadian delivered trucks had to have them by law at the time, from 1997-2002.
This picture is also useful because it shows on the left side of the DRL relay box, how the click-in box mounts to the steel mount point inside of the dash. Right near the circle water-mark, there is a black plastic tab. (This box is essentially show on its side, but normally that face is oriented "down"). If I remember correctly (not sure I do), the unit is release by sliding a real small *****-driver or thin knife (like a table knife) in, between that tab on the bottom, and the STEEL mount, then you push the box away from the knife to slide it off the metal tab that mates with that plastic tab. I do remember it is a pain the first time, and one has a tendency to snap off that plastic tab. So either go to a yard with more than one Expy, or be careful when prying that tab away from the steel bracket mount. Just pry enough to get it to release as you push away, and not even a little more...
