eastmonsoon
Hey all,
I have a 2001 Expy 5.4 that I just changed the plugs in for the second time. It has a reall misfire at all RPM's and shakes and judders through the rev band. The first time i goofed and put in Bosch +4's upon the advice of a local mechanic, then it started coding both lean on banks 1 & 2 and a misfire on cylinder #6. I read more on this forum and then change out to Autolite platinum OEM plugs and I am still getting lean on banks 1 & @ but no misfire on cylinder #6. Once i use the code reader to remove the codes it runs fine for about 15-45 minutes of actual run time.
My how to question is this: How do I test the vacuum lins property and the PCM?
