Rough idle? P0171, P0174? Here's what you need to check first!!!
Lane24
technical advisor
Alberta , Canada
Very common symptoms we all have at one time or another with our 5.4L is a rough idle where we will have high idle for a few seconds when slowing or coming to a stop followed by a drop off to a very low rough idle after stopped for a few seconds sometimes even to the point of stalling out.
I had this problem for a few weeks, and then the weather turned cold, and it got even worse to the point that my ‘ check engine light’ was even coming on. I took it to the dealer, and they replaced my IAC. No change. Still idled rough. Still had the CEL. The only change was the weight of my wallet!! So I turned to the internet!!!
By doing some ( a lot) of research on the subject from other Ford sites and forums, this is a culmination of what I’ve found out. The fix is a little rubber ’boot’ or elbow with a crack or a hole in it causing a vacuum leak.
The Ford dealer will run a diagnostic and indicate that it returned an error code P0171 and P0174, which indicates the engine is running lean. They will most likely recommended the following service:
Replace EGR valve - Replace PCV valve - Replace differential feedback EGR sensor -Replace mass airflow sensor -clean fuel injectors
all at a cost of almost $800. Yikes!!!!
The first thing to check is your vacuum assembly. You most likely have crack or hole in the little rubber elbow that connects to the intake from the PCV valve on the right hand side of engine. Even the slightest crack will allow more air to be sucked into the engine causing a too lean mixture.
The PCV valve is in the right valve cover... which is on the left side when your facing the engine (passenger side). It's under a lot of other hoses so it is very hard to see.. The hose goes back from the valve, then toward the drivers side to attach to the back of the intake way back between the engine and the firewall very close to the top of the engine. The common faulty part is the rubber boot that connects the hose to the back of the intake.
The way I found it was to follow the hose back from the valve cover. I sat right on the engine shroud, and felt for the tube sticking out of the top rear of the valve cover on the passenger side of the engine. With the engine off, it pretty much just pulled out and went back in real easy. Then I just followed it with my hand the best I could ( with the motor now running so be careful!!) until I got back to the firewall, and it actually comes up from underneath the rear of the intake. . You can kinda reach your finger up under there to where it's connected, and feel and hear a definate shoosh sound when your finger goes over the hole or crack in the elbow.. You can't see it, but you can definatley trace it back by following that tube. You'll know it when you find it because your finger will plug the hole, and your truck will start running smooth again!!!
The part number for the entire vacuum assembly with the correct boot on it is - F85Z-6C324-AA probably around $30 -$40. Or you might be able to just replace the elbow itself. Either way, make sure if you do have the leak, to make sure you have the replacement part handy before you take off the old one, because it will crumble in your fingers!!
Hopefully you just saved a few $100, and a lot of frustration. I know I was pretty happy when I found this easy fix!! Good luck!!!
firefighter407
Thanks for the post it came in very handy and saved me a lot of searching.
Just a quick question, is that part number in the picture is that just the elbow or for the entire assembly with the plastic tube too?
TxOutlaw
South Texas
Wish my P0171 was that easy on my Jeep... I chase that lean bank 2 all over the engine bay... Turned out to me a bunch of wires melted under a plastic covering!!!
Nice write up!
Lane24
Lane24
technical advisor
Alberta , Canada
Thanks for the pot it came in very handy and saved me a lot of searching.
The pic is just the part number for the elbow.. The entire hose assembly part # is above it in bold. It is F85Z-6C324-AA .
trdragons44
nj
i was wondering if this would cause the rpm to drop to 300-400 after putting it in park?
Blackwater
2nd this. I had the same issues. Turned out to be the same spot plus cracks just over the PCV
KWT2000
NINE MILE FALLS
hey thanks for this great post... on mine it wore a hole where it expands over the fitting heres the updated part number F75Z-6C324-JA....its the elbow / hard line and PCV valve it was $39 after tax five minute install
panda24619
San Diego
i had this problem about a year or so ago. mine wasnt the valve. it was the elbow in the back. i guess it was rubbing againest the firewall or something and waa laa a hole. went to take it all apart, broke the hard line of the hole. now what? well i went to a napa and the guy had no clue what he was talking about. went into another one. the lady there had the same problem with her 02 150. she gave us about a 4 inch piece of fuel line. let it soak and put the two pieces together. got a new valve too just because and no more problem.
OK98EXP
okc
Thanks for the post...Helped me out a lot! I have a 1998 Expedition Eddie Baur 4x4 with a 5.4 ltr engine. After hearing a whistling sound coming from the engine area and a considerable rough idle I recognized it was a vacuum leak of some kind. I traced the sound to a ruptured boot attached to a hard rubber line- very much described in this post.
My truck required a replacement Ford Part # F75E-6C324-JB (see photo) The part is also identified as F75Z-6324-JB. The part comes in two versions - heated and non heated which is identified by the "JB" code at the end of the part number. Lucky for me I needed the non-heated version which was about $29.99 from the Ford Dealer...$20 cheaper than the heated version.
I have attached photos of the non-heated hose. From what I hear is a 10 minute or less install...I called Pepboys and they said it was an approximate 1/2 hour repair and quoted be $35 to put it on FYI. Thanks again
UPDATE: Pepboys mechanic said the Ford parts guy was wrong and I needed the heated hose which actually has a second hose connected at a Y-fitting. Oh well...also after the repair the idle still was rough and the engine dies when a/c is turned on. Next step is the idle air control valve (IACV) which was a $40 part. This is not difficult to repair however is located in the same tricky spot as the PCV hose which is toward the back of the engine. Just gonna have my local mechanic put it on for $25. Will update after install.
UPDATE: I replaced the vacuum hose and the truck actually improved a bit however the idle remains rough and when gearing up to about 15 to 30 mph the idle gets jerky. I had the mechanics do a system check for codes and sure enough the #2 and #6 cylinder coil pack needs replaced along with a new spark plug. So the sage continues. Will update...
corvettej
Augusta, GA
Again, thanks Lane24 for the info, I had the followings codes on the 4.6l also, P0171, P0174, P2195, P2197 I took the cover off and reach behind the throttle body feeling for the hose end when I felt a dimple and placed my finger on top, I felt the suction and the truck idle smooth out I knew I had found the problem after replacing the IAC. The part from the dealer was only $29.00 where as the elbow was $15.00, so I got the whole hose and only had to push it on to install. Thanks , again for saving me some money.
smmjkg12
Camas, WA
Replaced line, same codes
Hi there,
I had the same 2 codes and found a hold on the elbow in the back as well. I replaced the whole assembly for $35 from the dealer. Reset the CEL and the car has been running great. 5 days after the CEL came back on and am showing the same codes, running too lean.
Any Ideas?
Lane24
Lane24
technical advisor
Alberta , Canada
Hi there,
Any Ideas?
Dirty MAF Sensor? I'm sure there are loads of info on here on how to clean it. If not, here's a link another member posted a while back with some info on it.
http://www.aa1car.com/library/ford_lean_codes.htm
RonnieGeo
Sacramento, CA
Same problem - THANK YOU!!!!
I had this exact same issue - thanks to your post (and excellent pictures) I was able to find the "elbow" by feel and I felt the hole. Bought just the elbow at Napa for about 13.00 and it runs great now.
Thank you - saved a lot of money having the mechanic search for this (already spent some and he didn't find it!).
Ken
Kurgenraider
P0171 error
Guys,
Would this then trigger a 1131, 1151 and/or 1506? I got em all along with 0156 and 1074. God love Ohio for requiring the e-check for otherwise I would just go on living my life pain free.
bigmax88
tennessee
is this the same on a 98 4.6 with the 2 coil packs? it looks like the pcv is on the drivers side and goes to the intake piping on mine. am i looking in the wrong spot?
Kurgenraider
Elbow fitting
Went to Car Quest last eve and they had the elbow piece on the wall with other small tubes and hose fittings. It was about $13.
aalex24
02 Ford Exp 4.6
I am unable to find that elbow, from what I can tell there is a hose that comes out of the PVC valve and then goes into the intake directly. Am I looking at the wrong place?
johel77
housto
Same codes po171 po174 po300
I had same codes show up few months ago. Reading some posts I looked for some vacuum leaks and in doing that I found a lot of gunk in one of the hoses on the left side of the engine as shown in pics. Cleaned that up and it helped a lot, but not completely smooth as it used to be. By the way why all that gunk formed in there? is the engine dying or something? it feels strong now. Any help will be greately appreciated.
Johel.
2001 Expedition 5.4.
lynn
Utah
2000 5.4
I started last week with high idle coming and going. The pcv valve was making funny noises so I changed it and the air filter. Ran good for a day than started again, one morning after being parked outside ( 9 deg. cold!!!!) would not stay runny, idle would go to low, until I reved it high for ten minutes to warm up. I checked the hose and elbows found no leeks took off the IAC looked ok little dirty looked in the throttle body and its realy dirty. I checked for codes with my reader and had none. So I went ahead and took it to the dealer and they said I had a clogged fuel filter they changed it and kept it over night and it started fine for them this morning. They wanted to do a trans and transfer case flush and filter change so I said go ahead I was think about that any way. I'm going to pick it up in the morning and hopefully it has no more idle problems if it does I'll start changing the IAC, TPS and that hose and elbow etc. myself.
Lane24
Lane24
technical advisor
Alberta , Canada
Don't forgetcleaning the the MAF as well. It's a5 dollar/ 25 second fix. Sometimes just cleaning it will make big changes to how you run.
