2001 5.4l Triton Engine Knocking Noise
stamp11127
Temple, Georgia
You can do that as long as the crank isn't damaged, the rod cap isn't bent and you check clearances before buttoning it up. You'll need a good torque wrench to torque the cap.
juan214
Stoughton, MA.
If it runs fine other that the knock. It may be a valve guide that split in half and is knocking up and down in the cylinder head. You did the plug check, then check exhaust leaks as suggested, then crank bearings as suggested. Beyond that everything else will cost money. If the a guide snapped it will sound just like an engine knock, your talking a head job.
Good luck
rjdelp7
2000 XLT
NY
Stick your head in the front wheel wells. It may be a exhaust leak at the manifold. You may have a cracked manifold or broken stud. Mine has a small leak in the front converter. Check them.
Sgt Darkness
East Tennessee
I don't have that kind of money. Theres no easy fix?
About 165,000.
I know the “don’t have the money” feeling. It really sucks. How’s the oil pressure? From looking at the vids it looks like you have done a recent oil change? My oldest Son buys cars that have same type noise and 7 times out of 10 a fresh oil change has corrected the knock. Dirt and crud can cause the lifters or a lifter to malfunction that’s why I was asking about the oil change. Trying to think of a cheap fix you can do without using a bunch of money.
Mad Oshea
Albuquerque
You may want to check the injector and coils. That will do it on a pause type ,Just to be on the safe side. Mine did that. 1st gen 5.4
1955moose
Stamp, Johnny Q ball might be in a pool table tourmanent like Minnesota Fats! What's your saying, **** their goes another Op!
stamp11127
Temple, Georgia
Guess we will have to wait and see if he returns with an update. Sad fact is if he doesn't do anything about it, the engine will.
I would expect a huge decrease in performance and a massive increase in crankcase ventilation.
Any mechanical machine "talks" to those that are willing to listen.
trhymers
minnesota
try a stethoscope on the catalytic converter. my pass side is knocking like crazy. banging on it with a rubber mallet you would hear a rattle also.
J
JonnyQball79
Washington
No I'm not gone. Just stressing and trying to find anything that will keep me from dropping the oil pan. :-( So after rechecking my plugs(hoping and praying), decided to check out the exhaust manifold. Found these two bolts broken off I think. I do not want to drop the oil pan.
