2003 Exp rear knuckle play.
Moemantha
Winnipeg
I have a large amount of play where the rear lower control arm mounts to the knuckles. You can lift the tire and it freely moves up and down 1/2" or more. Can the bushings be replaced on the knuckles?
FordandPolaris
Saint Cloud, MN
Anything can be replaced... From what you are describing, it sounds more like a ball joint problem. Because the 2nd gens went to independent rear susp. it will have lower and upper ball joints just like the front. I would replace the lower ball joint, and that should take care of the play.
M
Moemantha
Winnipeg
There's no ball joints: turns out its the lower knuckle bushing. Got 2 on order. Crazy play in the old ones lol.
FordandPolaris
Saint Cloud, MN
M
Moemantha
Winnipeg
They called it a bushing, but i'm sure it looks like that. I'll take pics.
FordandPolaris
Saint Cloud, MN
Sounds good. I didn't mean to be rude and call you out on it being a ball joint haha. I had no idea they looked so different from front ball joints. Good luck with the fix.
M
Moemantha
Winnipeg
All fixed. It was the balljoint, but it is a bushing. I'll post pics of the old bushings Monday. The were duuuunnnnn.
RFink
Tewksbury, MA
Re: 2003 Exp rear knuckle play
I know this is not a recent thread but I've got play in mine that causes the rotor to rub the edge of the bracket on right hand turns, left rear disc, ramps etc. Just bought a hub/bearing and this got me wondering.
