tripaphonic
Hey there community. Thanks for having a place to post questions.
Just bought a used 2004 Ford Expedition. As soon as I got in the thing the brake pedal went to the floor. Very soft. I could still stop but I had to stand on it. The brake light came on and the low brake fluid light came on. I checked it and found the reservoir nearly dry. I stopped off and grabbed a couple of 12oz bottles of Prestone DOT 3 brake fluid. It took nearly both bottles to top it off. Started it up, the pedal was still soft but not as much as before. Headed home and it did the same thing ... brake light, low brake fluid light, and standing on it to stop. Stopped again to grab 2 more 12oz bottles. I used both of them to top it off, again. This time I left the reservoir cap off, started the truck, and slowly press the pedal over and over to see if there was a difference. The pedal was definitely less soft and add the resistance that I would expect if it were working properly. Started home again after a few stops it started doing the same thing. Dead pedal. I inspected the underside of the vehicle, the brake line, around each wheel, the reservoir & the master cylinder; no noticeable leaks and no wet surfaces.
I just bought the vehicle a few days ago and inherited the problem from the previous owner. They had it parked for a while and offered no insight ... go figure.
Thanks in advance for any replies.
