2005 ford expedition not starting.
zamoraji2002
houston
When you turn the key you didnt get a start or a clicking noise.
I replaced the starter, we connected the battery again and it sounded like the starter started without the key on. We disconnected the battery and when i connected the battery again I am getting a big spark from the battery terminal.
jt_armstrong
Lake Forest, CA
Did you have to recharge the battery before fitting it? It sounds like you have a heavy short which is why your getting a large spark when the battery is reconnected. Might be that the problem is a cable with bad insulation rather than the starter.
Gruz7
North Smithfield, RI
Is it an unprogrammed key? I work part time as a locksmith and an 05 Expedition has the computer chip in the head of the key that needs to be programmed to the truck in order to start the engine. Usually if it's a new key or a key without the black top over the head of the key it will not start the engine and you'll need to call a locksmith to get the key programmed. Could very possibly be a completely different issue but I'm just giving you a suggestion.
Lithiatwats
Ca
Always disconnect neg first and reconnect last on battery. Don't want to short a cell or f-up your battery. If it was starting without key being on sounds like a polarity issue on your starter...
