2007 Expedition wheel upgrade
Florida
I have a 2007 expedition with 17 in wheels I want to get a set of used 18 in wheels and the f150 seems like only ones I can find that are readily available, but I read somewhere certain years of the f150 wheels will require modifications of my axles , so what f150 years will bolt on with no mods, I found a set of from a 2020 f150 with like new tires and wheels for $600,
I live in Florida so I don’t need winter type tires.
Traveler
Mesa AZ
LoL I'd love to get rid of my 18" wheels and get a set of raptor style 17" wheels.
Sent from my SM-S102DL using Tapatalk
07navi
Mt.Shasta California
J
Just cut 1/2" off the rear axles with an angle grinder................done.
Thunderbirdsport
Missouri
On the rear of Expeditions running F150 wheels, the axle end (where the nut goes) sticks out just a tad bit, it will contact the center cap. You can saw a bit off the end of the axle at no danger to the axle or nut so the F150 wheel's cap will clear...pretty easy to do. I'd think you could probably use an air cutoff wheel and make quick work of it.
Just be sure to do it with the wheel/tire off, and use eye protection....metal in your eye will make you have a hell of a bad day.
W
Florida
ok you guys are great , got the new wheels and tires on , just have to cut the axles a little, now
next thing that happened is the tire pressure warning light came on after a couple of weeks ,i thought i was
gonna be ok, so now i need new tpms sensors for all wheels right, from an 07 Nav?
Trainmaster
Old School Member
Rockaway Beach, NY
They should be easily programmed, unless the batteries in them went bad. Then they'd have to be changed. A tire place can check them out for you, or you can buy a programmer. New monitors are about $40 each+.
