So I have the craziest question and want to see if anyone has experienced this. I have a 2007 Ford Expedition EL Limited 4x4. My wife and I purchased about 2 years ago.
Well back last Oct we jumped in, put the key in and all the lights came on, seat pulled up and turned the key and nothing happened. Car never turned over, started or anything.
So I kept checking the transmission in park etc. Well after about 20 mins and fiddling with it, bam put the key in and it started no prob.
Well over the past 9 months this has gone on about 2 times a month. We might start it 20-40 times and it works perfectly, then all of a sudden is strands us. Its consistent for about 15-25 mins every single time.
This is hard to track down, because it is intermittent and no one can check it. I have had the dealer and mechanic friend and nothing. Its really aggravating as at this point I just want it to break so we can get it fixed.
Well this week it did this for like an hour, had to get the vehicle towed to Ford, backed it off the truck and started right up like nothing. Crap!!!
Here is what I have done thus far...
Replaced the battery- Feared it was a dead cell.
Did it once at home - So i got under and took a screw driver off the starter solenoid and it sparked and turned over. No crank
Purchased an ignition switch today - Have not put it in yet.
Here are my possible thoughts -
1. Starter and or Solenoid going bad
2. Ignition Switch going out
3. Neutral safety switch going out
4. Las but not least, a bad PCM/ECM module
5. Maybe a PATs theft issue?
I am about to start tossing these parts at it to fix. This is soooo aggravating. Has this happened to anyone else? Is there anything else it could be?
I dont know what to do?
Thanks for any help.
