Have you tried swapping bulbs, left to right (one at a time)?
No, removed bulb cleaned sockets and replaced.
The "3 bulb on each side" are The driving light, the front turn signal light and the rear turn signal/brake light and the third brake light? Same for both sides.That's what I suggested earlier. So puddle lamps aren't part of the 3 bulb signal on each side? Aren't all 3 wired to the flasher together?
You might just try to swap bulbs side to side. And while you have things apart, turn the signal on and move things around to see if you can maybe find a lose/bad connection.
I was reading in a different forum where they were reporting the same issue... fast flash but bulb wasn't out. He swapped out the entire light assembly (had a spare) and the issue finally went away. Not sure how the light assembly itself could cause a problem since it's plastic.
