2011 Expedition EL Limited Fuel gauge slow to show full
FORD-EXPY
Chicago, IL
Low fuel light on. Stopped at gas station to fill tank, once filled fuel gauge showed 3/4 full. After about twenty minutes gauge finally went to full. Operation seems normal now. Anyone else seeing this?
mquick5
Buckeye Country
Sounds like early signs of the fuel pump failing.
99WhiteC5Coupe
Try two consecutive treatments of Techron Fuel System Cleaner (prior name was Fuel System Cleaner PLUS) according to label directions. It is sold in 12 and 20
The cleaner removes sulfur deposits from the in-tank sending unit, which can cause erratic fuel gauge readings.
GM and Chrysler sell the product under their own brand name, which is made by Techron, for this problem. GM has issued several TSB’s instructing dealers to try this method when receiving complaints of erratic fuel gauge readings.
The deposits seem to form more often when using non Top Tier fuel.
Plati
I've had that off & on over the years on my 2003. Was told sulpher buildup on float sensor in tank. I do not know if your year has a similar float sensor. I always ignore it and it goes away.
How could a fuel pump cause this?
purevw
Was the ignition off when you filled it? If the key was on when you fueled, it's normal for it to take a long time to rise.
F
FORD-EXPY
Chicago, IL
Thanks for all the help on this
A) I started the Techron Fuel System Cleaner procedure. I have yet to get thru one full tank but will post result
B) yes, I did have the car running as I was filling the tank...I probably do that 80% of the time, but this is the first experience with the gauge being slow. Moving forward, I will turn car off.
Thanks again for taking time to post suggestions
ManUpOrShutUp
PA
I'm putting in a vote for the fuel level sender as the culprit. I've had the issue for 4 years and don't give it much thought now.
bobmbx
Thats the problem.
16plati
VA
Everyone else filling up at your gas station will thank you for turning your vehicle off while filling like the signs on the pump request you to.
