Josh Raley
Ok thank you I was holding the break pedal until I got to bank 2 then letting go and trying to get into the sub-banks, I'll go out ant tey that in a few its about 117 outside today
Ok went back out and followed the above instructions to the tee and still no horn honk with break pedal press
Perhaps your '12 Navi has a different system. I've got the System 100 in my '11 Expy, which is the manual excerpt I posted. Can you pull a model number off the brain?
Check and clean the terminals on your horn....see if that helps...
Sent from my LM-G710VM using Tapatalk
I have attached a PDF on remote starter programming from Ford. Maybe it will help.
