2012 EL Limited rear suspension fully inflated
USMCBuckWild
Camp LeJeune, NC
Yes I searched; NO I don’t want to swap out for coils.
Rear suspension appears to be at MAX height and the “Check Air Ride” light on the dash, but no actual codes. Truck has NOT been jacked up/lifted with a jack, totally stock with stock rims/tires.
Turned air ride off; didn’t lower at all. Checked fuses; all good. Checked lines; all good. Can’t get the compressor to cycle (haven’t started jumping wires to force it yet). Disconnected battery to clear system. Suggestions before I manually deflate the bags? I want to avoid letting all the air out and then having to wait on parts if I can identify them first.
Advice on what to check/test.
