iamretired
Need some help! I Bought this 2015 expedition from SLC auction, it was a Unified Pd police vehicle and came with a havis radio mount and arm rest on top of center console. I still can’t figure how they killed the interior lights from going on when doors are opened, but they turn on individually when pressed on? They gutted the center console, no armrest hinge, or box and no 12volt socket, no usb and etc. I bought a used 2017 expedition console with arm rest, box with hinge, 2 usb ports and 12 volt socket, but the wiring is different. When I dismantled the 2015 console I did find a ford usb full size plug FL1T-14D202-CA and a 3 wired connector with a yellow/green wire, a solid blue wire and blue with dark blue striped wire, buried in bottom of console frame. 2017 console box has a 12 volt socket and 2 usb ports, with a mini usb connector FL1T-14D202-BA, which looks like it is connected to only one of the 2 usb ports in box and 12volt socket wired with black purple stripped wire and blue red stripped wire going to 2017 console loom, which I cut off and usb lighted base wires I guess had a yellow green stripped and a white blue stripped wires which I also cut from 2017 console loom. The 12 volt socket wires I am guessing the black purple wire is the same but the blue red stripped wire is for 2017 and the 2015 wiring loom has none maybe uses the yellow red stripped wire?
For the usb in the console box I did try and use a mini to full size usb extension and it does not work, maybe between the 2 ford usb connectors has it wired different? 69 years old, always wanted an expedition and trying to figure how to get this wired right? Sorry for the lengthy post just trying to be clear. Thanks for any help I can get! And can't figure out how to attach some pics?
