Man you’ve been a huge help thanksThat is correct. When the second gen ecoboost motor came out (2015+ F150s and 2018+ Expeditions) the ICs and charge pipe configurations changed. I would look at mishimoto website under 2014 F-150.
A catch can could also solve that issue...I’ll chime in,
As others have mentioned, I had multiple cylinder misfires on my truck last year while towing my camper across the US. I had changed all my plugs and coil packs for the associated cylinders listed in the code scanner but it didn’t fix the issue and the truck ran terrible. I had just driven through a major elevation and temperature change so I thought maybe there was condensation buildup in the intercooler and even though the problem is supposedly fixed in our ecoboost expeditions I drilled the hole anyway while parked at autozone somewhere in California. Immediate oily juice came out and after two days of the truck running terrible and throwing multiple cylinder misfires, it immediately fixed the issue and I haven’t had it since. I’m 100% convinced we still have a moisture buildup issue in the IC that causes us to have misfires as the spark plugs are essentially “blown out” by the moisture. Solved my problem at that was a year ago. I now have 136,000 miles on my 2015 Ecoboost and haven’t had any issues.
First off both are wrong, the Wagner IC doesn’t have the option for our BOV so that won’t work at all. Second, the mishimoto IC you posted is for a 2015-2016 f150 which will also not work as it’s different dimensions then our 15-17 expeditions.stage 3 intercooler is $990
https://www.stage3motorsports.com/2...ion-3.5L-EcoBoost-Wagner-EVO-Intercooler.html
or Mishimoto complete kit for $1350
https://sportcompactwarehouse.com/m...=Ford&Model=Expedition&gsID=pxf1718747f64215&
how much is a tune? what programere did Yall use?
No 100 even to the wheel for both on 93 octane perf tunethank you for the clarification.
with tune what are the gains? 40-60hp?
