Back in march I installed the 55W HIDs in my Limited EL. Several guys cautioned me not to use them because of higher heat, shorter bulb life etc. I did a lot of research online but I could not find anything that conclusively pointed to these issues other than that the 55W used a standard HID bulb but just put more current to it.
Fast forward to Sunday night. We were sitting in the drive thru line at Zesto's the local ice cream chain and I noticed that my driver's side headlamp was out. I turned the lights off and back on but no change. Monday morning I immediately reached out to XenonHIDs.com. They said to follow the troubleshooting procedure. Anyway in the back of my mind I kept thinking that I wanted to go with the 35W HIDs that's what I had in my 05 and they worked great plenty of light etc. So I ordered a set with the canbus ballast because it developed more lumens than the cheap ones.
The new system came in today and I installed it.
Before I post any pictures of the new install, I did make some interesting discoveries on the 55W system. I switched the ballasts, then igniters, and then bulbs from the side that was working and everything worked. Then I tried the individual components from the side that wasn't working and they worked. The only thing that I can think of is that one of the plugs must have been loose. Incidentally the double stick tape that held the ballasts to the side of the headlamp housing failed and both ballasts where hanging down on their wires.
I removed the 55W system components and installed the 35W system. The 35W system does not use separate igniters for the bulbs, they are built into the ballast. The ballast I mounted by using three small sheet metal screws that I coated with silicone and then drove them in being careful not to strip them. I used the same gray waterproof rubber duct tape to seal the opening where the wires pass through the housing. I checked the headlamps to make sure they were working and then I reinstalled them.
When it get's dark enough outside I'm going to take it for a ride to see if I notice a difference. I also raised the right hand headlamp up because it has always felt like it was pointing too low.
Lol same crap with mine....except theyre 35s.
One of the ballasts is going "lazy", sometimes doesnt ignite the bulb (i know this cuz i already swapped bulbs)
But Im blaming myself, putting like 1000 hours of always-on operation on them (got lazy wired it kinda oddly, headlights flicker in DRL mode unless set to fully on)...AND my habit of double--tapping at traffic signals, since mine is wired up with no highbeams whatsoever and pulling the stalk instead cuts all power to lights until released...
I've GOT to tease you brother.....how much you into those headlights now???? Hmmmm????
I've got 35 bucks into my LEDS!
Relax brother, I'm just yanking at the chain hanging right in front of me!!
If I can't f*ck with my friend, who can I f with??
jeff
My 35w HID kit was $29 i think....35 bucks that better be some posh LEDs
