2017 Ford Expedition Platinum EL 4x4
83,000 miles
I decided to change the spark plugs on my wife's Expedition. The Expedition was running good. No issues with idle, drive-ability, or anything. I've read different opinions on when to change them. So I thought why not go ahead since it is a boosted engine. We don't tow anything yet. The Expedition is completely stock save for the catch can which was installed in the last 2 months. We recently had the water pump start leaking but that was replaced under the CPO warranty.
The replacement was actually quite easy. The right side (passenger) of the engine is easy. Plenty of room to access the plugs. The left side (drivers) was also easy. I did have to unplug the connector the to whatchamacallit (I can only guess is the high pressure regulator??? between 5 and 6). All of the plugs were gapped over .045". To me, the old plugs look good other than the gap. The NGK Ruthenium replacements were pregapped to .030". The manual says .030-.033" so I left them alone. I used NGK Ruthenium HX 90495. I used NGK Ruthenium's on my Hyundai Genesis 5.0 with no issues for more than a month.
I thought this might be helpful to others that are trying to decide to change themselves. I used 3/8" ratchet with 4" and 6" extensions, spark plug socket, 1/4" ratchet with 5/16" socket and extensions, and a magnetic pickup to pull the plugs out. The hardest part for me was pulling the coil over plug off the old plugs...a little patience. Don't drop anything as it can be fun finding it...without dropping the pan covers and skid plate.
83,000 miles
