2019 Expedition grinding while turning in reverse
jimmymaniaci
washington, Missouri
I purchased a 2019 expedition platinum with 53,000 miles a couple days ago. So far everything seems to run fine, except when backing up into my garage while turning I can feel a grinding/rubbing noise that seems to be coming from my front wheels. Almost as if my 4x4 is kicking in. Any help would be appreciated on figuring out what might be causing this.
wakeboarder
Fort Lauderdale, FL
The 4wd hubs may be engaging when they are not supposed to. There is a known issue with this on the 2018 and 2019’s. Do a search of the forum. Does it do it in 4wd auto as well as 2wd? If it does it only in 2wd, then it is more likely the case.
J
jimmymaniaci
Is this the IWE rings you are referring to? I still need to try with 4A. I noticed that it didn’t seem to do it after I started it and backed out of a parking spot. But then when I got back home to back into the garage turning onto the drive way I noticed it again. I’m hoping this is covered under the warranty yet.
wakeboarder
Fort Lauderdale, FL
Yes, I was thinking the IWE actuators. I have a two wheel drive, so I don’t have any experience. I was just throwing out as a potential cause. With the IWE’s some people have commented that it makes the noise while turning.
