2019 Model actual MPG way lower than expected
16plati
VA
You must be getting into the Turbos or carrying some extra weight. I'm now (non winter) averaging 18mpg by the Ford system in a 17 EL with 3.73 gears with a 6 speed auto. I use 93 octane. The truck is all stock. I do about the same mix of Highway and local driving as you. I mostly use 2wd. I do see a drop off when I do use 4 auto. I used to drive at 80mph on the highway when I lived down south but have dropped back to 72-75 on the highway because the limit is 65mph here. I don't drive it easy but don't accelerate hard at every light either. Also It's me mostly in it and occasionally my 2 greyhounds.
The turbo system is basically adding capacity to the motor. I read somewhere but can't find the link that when you are in full boost you are running the equivalent of a 7.0L motor. It's when you are not into the boost and lower speed we pick up the mpg savings.
I’ll second all of this. 2016 platinum el 4x4 3.73s. 93 oct, custom performance tuned, lifted on 35s and I’m getting 17 in the city and 22 on highway at 65mph all day long
Plati
Mine’s shockingly inefficient until it warms up all the way...
I swear my 2014EL 5.4 gets a couple more mpg after it warms all the way up … as in after an hour of interstate cruising. I've never run an exact test on this, just check computer reported mpg at various times. I'm gonna stop driving it cold, only when its fully warmed up … to get the optimum mpgs.
CyberVinnie
Pittsburgh
You also have to consider terrain; the hills in western PA kill my MPG regardless of the car I drive. Even my wife's new EV range is impacted by the hills.
lbv150
Northeast
I will not drive any vehicle or operate equipment until it is at normal operating temp. I find the '16 Expy takes the longest to warm up. Good thing for remote start.
tl01
So Cal
Doesn’t seem far off to me. Do you do any idling? I know I do something with picking up kids from school etc or using remote start. And hills in that driving? Driving style too... I know I floor my cars each time I get on the freeway so I never get close to stated mileage
S
S13ka24de
New york
When is the 14.7 from? Meaning, from the trip computer from day 1? Is it more recent average from last couple thousand miles? Still seems pretty low overall even if factoring in break in period and even if running 87..
I only use 87 octane and have 6,500 miles. Trip 1 is from the day I picked it up my 2018 w/ 7 miles back in early December. It currently shows 17.8. Trip 2 that I reset and now shows about 2,000 miles is at 19.1 mpg average. I'm probably opposite you and more like 2/3 city vs 1/3 highway. This is also in Michigan w/ some pretty cold weather bringing the average down.
It is from the beginning
mpc11
MI
Hit reset on one of the two trip displays and see what you now get. Also, are you in 2 wheel or 4 wheel? What drive mode; normal, sport, snow,..?
Plati
I don't seem to have that result (driving through West Virginia or Rockies). Never ran a thorough test though. Yes it takes extra fuel to go up a hill …. /….. but then you coast down that backside ….\.… Seems like it balances out to me? What goes up must come down, and the exact same elevation change both ways. So overall its a wash?
grumpyoleman
flyover country
18 Expy XLT 4x4 with only 1100 miles.
hand calc'ed after 500 mile road trip (country roads with slow downs/stops every ten miles or so for small towns) = 18.4 mpg
This is my third vehicle with the 3.5 EB and one thing I have learned:
the more you smile at the "boost" the less you will smile at the "ECO"
its one or the other.
EricExpedition
Georgia
2018 FX4 MAX with 20K miles and we are getting 20.9 MPG (dash). Wife is the leadfoot, but both mostly highway driving. We were getting 20.1 MPG (dash), but now that it is starting to warm up here in Georgia and I added a K&N air filter a couple months ago, it is continuing to improve. I only fillup with 93 octane before a trip. I always disable Auto S/S (thanks for the product link!) and also stopped using Eco mode. We had to lean more into the throttle to get up and going from a stop (personal problem) AND it seemed like it was always running at higher RPM's at 60+ MPH than in Normal mode (Ford's problem).
I even get 15.1 MPG (dash) in my 2013 Ecoboost F150 4x4 with 35" A/T tires and a leveling kit. I would say your 14.7 MPG is abnormally low for someone with conservative driving habits.
CyberVinnie
Pittsburgh
You are assuming an inverse relationship between fuel consumed traveling uphill versus what is consumed traveling downhill, and I think there are far too many variables to make that correlation (speed, grade, road, load, accessories, aerodynamics, transmission, etc.).
Also, are you suggesting you get the same mileage driving through the Alleghenies or Rockies as you do driving across flat terrain like the Midwest?
Washington State
It sounds like your engine is not completely broken in yet.
When I first got my '16 it was getting an avg 15 mpg. Now at 30k, I'm at an avg of 18 mpg. A F150 buddy with an EB 3.5 works his truck hard and gets an avg 22 mpg "unloaded." I'm convinced normal driving will not sufficiently break in these EB's. It's almost like a diesel where you need to work them early on otherwise power and economy will constantly suffer.
NyackRob79
Nyack, NY
What kind of a city? Suburban town, or gridlock NYC traffic? Because during my NYC commute I average about 8mpg. That's the price for driving a 3-ton hunk of steel at 2mph.
Suvdude2000
Here
14? Yikes. I currently have a 6.2l 420hp yukon and get 18mpg around town. Gas mileage wouldn’t stop me from getting an expy but jeez.
16plati
VA
Factory boost ain’t nothin! 11-13psi stock, I’m running 22!!!
dlcorbett
Air Force
tx
If you baby it and use eco mode, youd get the same in the expy. Its not hard to get good gas mileage out of these bad boys if you patient.
dlcorbett
Air Force
tx
Hammer the expy then lol. Sport mode turns my tank to a break dancer. I dnt put her in sport often but i live when i do. Even still my lifetime avg is 21 mpg per computer but mines is def broken in at 25k
Suvdude2000
Here
What do you get around town in sport?
I don’t really care about the gas $$$. Gotta pay to play...but it’s just odd to me Ford is so married to the idea of a smaller engine with blowers...Why not throw a big v8 in it...get the same gas mileage, never overwork the engine and get a nice exhaust note...
And no. I’m not a GM guy so I’m not bashing.
