2022 Timberline Issues
KetMalice
Oklahoma
Basically I’ve had all sorts of issues with mine, headlight assembly replaced, 15” screen replaced, APIM, replaced, HVAC module replaced, center speaker cover replaced (warped).
Basically Ford has said the fit and finish on the 22 Expeditions is poor, and you bought it that way, so they aren’t fixing things like all of the plastic pieces that don’t line up.
Wireless CarPlay still doesn’t work but maybe 25% of the time, and it still crashes on every trip. The screen/software itself when using USB still locks up. Ford has just said they aren’t fixing anything else because they are continually doing software updates.
SyndicateZ
Mass
$80,000 worth of problems
Quandary
Colorado/Wisconsin
Basically I’ve had all sorts of issues with mine, ....... HVAC module replaced, ............
I am curious about the HVAC module being replaced. Mine heat seems to run on the warm side regardless of the temperature I set the heat at. Is this the problem you had?
