24" wheels on the '11
FormerStangFan
California
So I just ordered a set of 24x9.5 wheels for the expedition and should be here in a day or two. The question I have is should I run a 295 or a 305 tire and if anybody has any issues with tire rub. It's a 2 wheel drive stock height with no plans on lowering it
jacks3am
michigan
talk to freeway, I think he went with 305 but dont quote me on that
sgtowing
Supporting Members
Valrico, Fl
Freeway does have 305's. Pics or it never happened
Sent from my DROID BIONIC using Tapatalk
Newport News, VA
i have 305's...295 vs 305 doesnt change anything...its still a 35/24 tire...so the revs doesnt mean anything...i would suggest 305 to give you tire protection against curbs..you really cant tell the difference when looking at them...the tires i have have "rim protection" where it's designed to give the lip of the rim coverage to protect against curbs...since you went with a 9.5" rim it should look identical to my 305 on a 10" rim...
what brand/rim did you go with?
WHOISMOOTOO
Dallas, TX
305's!!!!! you'll see why when you buy tires 295x35x24 usually run $50 higher per tire, 305x35x24 is the most common so its cheaper to get. I found this out helping a buddy of mine get tires for his navi on 24's. he had a 24X9.5 and I have a 24x10 as freeway said theres no noteable difference
F
FormerStangFan
California
My tires are $600 flat price regardless of size for the 24 my boys shop so I kinda get what I get when I can. As far as rim protection I have plenty like you said its only a 9.5" wide wheel. The only concern I had was if there would be any rub turning lock to lock but there is none. It looks fine with the 295 and ride quality didn't suffer too much from those monster stockers.
Can't stand how small the brakes look now but I have some more important things to take care before I out more money into this thing.
F
FormerStangFan
California
If you do the calculation the 295 is within 1 rev per mile ofthe stock 275/65/18 and the 305 is about 6 revs per mile off
Newport News, VA
30's will fit and not rub....i've seen it done...no mods done for it either...i wouldnt go that big...26's are a piece of cake and 28's turn easy...
F
FormerStangFan
California
You know Freeway, once they were on that's the first thing I said. Should I go 26 instead. LoL. Fitment is clearly not a concern. I guess I just drive it way too much to deal with the ride quality of a bigger wheel and a smaller side wall tire. I have to admit the pure size of these trucks makes the 24 look much smaller to me though.
dj2big
Chicago
I am thinking 24" but with the thickest tire possible without out rubbing potholes in chicago are horrible
Sent from my iPhone the power of the Jedi
Newport News, VA
@ formerstangfan...i was thinking about getting those in 26's...chrome though...how much you get the hook up for?
rayt
NY
wow those other rims linked are massive! I just got a set of 2010 f150 harley davidson rims and i was thinking that 22" was big as it was lol.
dj2big
Chicago
So what are the widest thickest best protection tire for 24 or 26 without going to much off oem specs
Newport News, VA
i have 305's with lip protection...you can go 315 but that will run the pricing up...dont see a need to go past 305...thickness aka profile series...i have 35's...so my tire is 305/35/24...i have no problems with them...my ride comfort is good too...you can go 40 series and shouldnt be a problem since 30's will fit on our trucks...but that will make them look like 22's...
26's...same deal...305/30/26 is the standard tire...you can go 315 and thats probably where i would suggest you stop...325 may require adjustment and may rub on the inside
im going to move up to 26's...then eventually buy 28's for shows
