3rd shock blown out on 2018 XLT
ManUpOrShutUp
PA
Ah, that would do it. The way I read it quick struts didn’t have a cartridge insert so thought it would be covered. But I only know slightly more than I did yesterday about suspensions, which was nothing.
The entire strut is covered if it's a Ford extended warranty. If it's a third party warranty, wtf knows.
My 2019 has 20,000 miles on it. Dealer checked and 3 shocks are leaking. They are replacing 3 under warranty and I asked just assuming they would do all 4. Dealer said we can only replace the impacted ones under warranty. Do you think there will be issues with this going forward? Seems like a shock with 20,000 miles on it and 3 brand new ones isn't the best setup.
Ideally, they should be replaced in pairs. However, if you have the dealer do that other one you will pay out the nose vs having it done at an independent shop. I would just leave it alone if it were me. Chances are it's going to fail along with one or more of the new ones. I had one rear blow out at 80k and then another at 90k. By 110k, the first replacement was leaking like a sieve and the second replacement had a minor leak. At that point, the extended warranty was up and I opted to replace both with Bilstein 4600 series. No issues since.
daytonajrw
Doylestown, PA
how are you getting it covered? I have the Ford Used PremiumCare and they are claiming it's a shock and not covered. it would only be covered under the premium maintenance plan.
Squark
NC
PremiumCare covers struts but not shocks. According to the Ford parts site, our fronts are struts and rears are shocks (even though the rears are coil-overs and look very similar to the fronts). After having 6 leaking factory shocks by 40k miles, I decided to switch to Bilsteins.
ManUpOrShutUp
PA
I had my truck in to my local trans shop for routine maintenance and he noticed a leak in the rear. I took it to the dealer and he told me it wasn't covered as their system said there were shocks in the rear. I got the trans shop on the phone and he said: "It's a strut. Put the Ford tech on the phone and I will explain to him why it's a strut." I relayed this message to the tech who said he would put it on the lift and get back to me. He called me an hour later and said: "It's a strut. It's covered under warranty."
I know this is a old thread but been searching the forum and cant find a exact match (I most likely have missed it)! We jsut purchased a 2019 Expedition MAX XLT FX4 with MAx tow Package (I believe it has the Max tow package as it has the trailer break control inside and the trailer back up dial). Took it for a longer road trip and noticed on the highway the vehicle wanders in the lane and the steering feels lie there is play in it. (50,000 miles and wifes car so i dont get to drive it much)
I took it to the dealership for a Oil change and tire rotation and asked them to look at it. They just called saying it isnt the alignment but all 4 of your shocks are bad and that is what is causing the wandering and loose feel which is more noticeable on the highway. They want $2,300 to replace all 4 shocks which i dont believe is ahppening, Also said my rear brakes are low. So looks like my good friend (a retired pilot who is a pretty good shade tree mechanic) and I might tackle the shock change and new rear brakes. a couple Questions
1) does the wandering in the lanes and "loose steering" at highway speeds sound like a shock issue. Ill be honest i dont know that i would say i feel a bottoming out as we go over large bumps as i typically am in tune with how the car is reacting but i could be wrong. I havent seen any oil in the driveway if the shocks have recent busted like many on the thread.
2) I have read here that a lot of people are putting on the Blisten 5100's. I might go that route but would like yalls "professional" opinion (yall have a lot more knowledge than me and experience on this matter and these vehicles so yall are professionals to me=) ) This vehicle is 95% of the time a Soccer Mom vehicle transporting our 5 kids around but we do pull a 2006 23' Malibu boat that weighs probaly 6500lbs multiple trips a year. We do not go off roading in it. Looking for the best shock with a good quality ride no off road performance need. also not necessarily looking to level it either but neve a bad thing.
Sorry for the long post but trying to get yall as much information as possible. Thanks for the help.
ManUpOrShutUp
PA
Seems unlikely that all 4 shocks would be gone, but that price is ridiculous either way. You could have a shop for Bilsteins all around for less than half that.
I have the Bilstein 4600s. Slightly stiffer than stock, but that's a plus for me. Better handling and a little less cushion vs stock. I tow occasionally - anywhere from 1,500-7,500 lbs with most runs falling around 3,000 lbs. I've been running them for 90k+ miles and they're still going strong.
Ya the price was so high I am almost wondering if i heard him wrong over the phone but I swear i repeated the price and he said yes but ill confirm when I go pick it up. Bilstiens seem like the go to shock. Ill try to google the diffreences in the 4600 and 5100 and other options.
duneslider
Utah
I put the 5100's on mine and love them. They have a little stiffer feel than the stock but not a massive difference but I do feel they handle towing better. When I removed my shocks 3 of the 4 were leaking but only one was leaking heavily.
I need to do the rear brakes on mine too, just picked up pads the other day and need to make the time to do it now. Shocks/struts weren't too bad to do, I got all 4 done in about half a day by myself. I picked "stock" height on the struts and when I had the alignment checked it was perfect so nothing was needed that way. I suspect if you add lift it will need some alignment.
ya I'm trying to find 4600's but it Im not finding them the fit 2019's. MAybe the only option is the 5100's for the 2019's. I think i will at least take it to another shop to confirm if they believe the shocks are bad. Of course this all happens a week and a half before we are supposed to drive from Houston to Utah on a ski trip.
@duneslider I have read yall are needing a little more snow but I might be the only one wishing no big snow dumps betweem Feb 4th through feb 11th becuase i know if it does everyone will come out of the woodwork and hit the slopes! I rather not have huge lift lines in at Alta and Solitude but it is what it is atleast it would be good snow if it happens (but being from texas we dont know the difference in good snow and bad snow!)
ManUpOrShutUp
PA
It looks like that may be the case.
m3bs
North Augusta SC
Does anyone who has made the switch to Bilsteins have their stock shocks laying around? I'm working with a company to produce an alternative replacement shock setup for our Expeditions.
beefsolar
Huntington Beach, CA
Second time around for me with bad struts. First time had a leak in the front along with a bad axel bearing and boot whipping grease out. This was at about 12k. Now I have all 4 struts leaking at 44k. Left rear dumped out on my new driveway. Good thing is they’re all covered under extended warranty, which sounds lucky based on previous posts. Maybe I should order some of the Bilsteins in preparation for the next time they fail and I’m out of warranty!
5280tunage
colorado
That's absolutely insane, all four leaking at 44k? what a joke, this sounds like a consumer class action type thing if it's this widespread.
JasonH
Houston, TX
MikeTheApeman
New Jersey
43,930 on my 2018 XLT. All four leaking. I'm slightly pissed because I bought it CPO 18 months ago with 34,205 on the odometer. Only 9,725 miles, never towed, never off-road, 50/50 city and highway...and dealer is telling me not covered under ESP. I find it hard to believe that there was no sign that these were worn, but they also sold it to me with bad phasers that (luckily) I got replaced under warranty at zero cost to me.
Quote for all 4 shocks (including an alignment @ $125) was $2,054.
KenK
Houston
Like many others here, I went with the Bilstein 5100s rather than fool around with getting the originals replaced under warranty.
The dealer said I had to leave the truck for a week just for them to look at it, and then they would order parts.
Because they are struts at all four corners, it is a big job to DIY.
I also got the alignment tweaked after changing the shocks. It was not far off, but just enough.
So far, I'm happy with the Bilsteins. They do seem a little firmer and more controlled than stock.
I cannot say the ride is greatly improved but I think that is related more to the Michelin Primacy tires which are next to go.
Several friends have the BFG K02s and recommend them highly.
Since changing the shocks, I did some light towing under 2,000 lbs and some moderate hauling of 1,000 lbs +, and there is a noticeable and pleasant difference.
2018 Max 4x4 + towing package
~ 33K miles changed to Bilstein 5100s
~ 37K miles now
