5w40 vs 5w30 for 3.5 HO?
rd618
new york
I agree with you 100%. The recommendation for brand and type (not weight) are typically based on relationships of vendors and money. So going to full synth or one with additives, etc can have benefits.
But when it comes to the actual weight, since all brands have weights of every spec, the recommended weight from the manufacturer is typically the recommended weight from the engineers. Most people assume a higher weight is better which is not the case. Engines like the Triton and BMWs typically run lighter weights by design.
IMO the rule of thumb is
- Run the weight recommended by the Manufacturer
- Run the brand & type based on what you prefer and what others recommended especially if it has a history of performance for a particular engine.
The big thing people overlook is warrantee work. Your engine runs into an issue and they run a sample of your oil and figure out you’re running the wrong weights. They can easily deny a claim.
5w-30 vs 5w-40 isn’t a big deal but why change the weight? Thicker at operating temp isn’t helping flow or lubrication if the engine isn’t designed for it. I agree with sticking with the manual.
this is the same argument people who think 93 is better when the engine recommended 87 octane. Might not hurt but probably doesn’t help.
(Side note is the 3.5HO does recommend 91+ for optimal performance)
5280tunage
colorado
My .02. in both my regular street and racing vehicles, I've always faired well with two brands, mobil1 and Royal Purple. During summer months here I usually run the mfr recommended weights, but in the winter I usually run one cold weight lower. So 10 to 5 or 5 to 0. As long as the hot weight is at least as good, no one can possibly argue that a more viscous cold weight will hurt. In fact, sludge conditions are the same as cold heavy weight limiting start up flow. These motors that apparently have plastic components that fail quickly without enough startup lubrication, should only benefit from that. Not to mention, I know first hand that two identical jeeps, sitting at 10k feet elevation at below zero temps, only one started easily and quickly. The one with 0w20.
I also believe that good filtration is almost as important here. Again. I really like the same two brands which offer pure synthetic filters. I didn't like fram or even k&n.
I haven't had my oil tested in this, but previous vehicles showed that even when prolonging oil/filter life by say 10-20%, the right oil and filter combos kept everything within specs.
The only thing I haven't done here but I used to do a lot were additives. Curious in folks thoughts here. I religiously used things like BG or Lucas additives in previous vehicles and always seemed to have good results. In my hemis, I always had cleaner breathers and changes, using Lucas products. Could be a complete coincidence but used to have less build up on exhaust components even.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Again, 5W-40 should only be an option under extreme conditions. Heat, pressure and so forth. I am pretty sure I said that. 5W-40 and 10W-40 are typical diesel oil weights for this exact reason.
As far as the Octane...Nope, Terrible comparison. Most Turbo motors will run better with higher Octane. Less knocking and timing pulled leading to more efficient running, and more power. Remember these get there rated power and MPG at 92 Octane. Anything less than that, and you aren't getting what you paid for, PERIOD. If you have done ANY logging on these EcoBoost powered vehicles you would know that. These motors don't tune UP for higher Octane, they DETune for lower Octane. There is a distinct difference.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Great breakdown. Good oils and good filters! Big fan of Royal Purple products. I typically use their ICE(Coolant enhancer), and Octane booster when I need it because of access to lesser fuels.
I have used Ceratec by Liqui Moly in the past. Good results on my VW TDI's when I did oil analysis. Haven't typically put it in my Fords, because of less extended intervals for change. I have been using FR3 by HotShot Secret after oil changes in my 2020 Expedition, my Previous 2020 Explorer ST, and my Current 2021 150. It is fairly cheap when broken down per oil change, and I have seen some promising analysis of it. Is it helping, well without an analysis, it is purely subjective. The Expedition seems quieter on cold startup once it is added to the oil. Again, purely subjective.
Fixed per @JohnSC's Recommendation!
JasonH
Houston, TX
Has anyone seen any persistent evidence of internal engine failures due to oiling issues? I'm sure we're all aware of the cam phaser issues, but apparently that was a design defect. I'm not aware of any other persistent issues with the Ecoboost apart from (1) cam phasers and (2) turbo manifolds.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
No, not that i have seen. The 3.0 sometimes have an oil consumption issue in the first 5-10K, and a oil starvation issue on hard accel(More of a pan/pickup issue). The Ecoboost raptors have had similar issues as far as the oil pan.
Now the phasers could be helped by a good oil or additive, something that stays on the phasers. One of the TSB's causes oil to flow more before the motor cranks and fires for just this reason.
rd618
new york
You missed the point of my post.
I’m reiterating sticking with the manufacture recommendation. I agree with the other poster’s comments.
As for people suggesting heavier oil weights, there is no evidence they help these 3.5EB more compared to the recommended weight.
Regarding the higher octane, I mentioned what you also said, these 3.5 perform better with higher octane (I run 93, but that isn’t available everywhere).
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Understood. No I got it, was just clarifying.
I am bit hyper sensitive about the Octane discussion because there is SO much bad/incorrect information out there in regards to these Ecoboost Motors. You mentioned the HO motor specifically, but ALL Ford gas motors are rated with a standard fuel that is 92 Octane. Safe to run 87(Minimum), but won't get rated power or MPG. I always like to clarify that. The fact 93 isn't available everywhere is why Ford say 91+. 91 being the lowest Octane Premium standard found in the US. Still at 91 there is a possibility of less than rated, but not likely, because the fuel used as the standard has NO additives, and even a decent additive, and little Ethanol will make up the difference. So it would have to be BAD 91.
Expy Gator
Florida
I'm sure the fuel Ford uses now as a standard has additives. It's a federal law. Back in the day not all fuel had additives.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
You would be wrong. The fuel used to certify most vehicles nowadays is an industry standard fuel. It is basically plain 92 Octane gasoline. No additives, and no Ethanol. There I believe is something in the works to add Ethanol to that fuel, and use a fuel that is closer to the fuel available to most, namely E10.
