7 broken plugs
jontanner
Charleston
Recently picked up a pre owned 06 king ranch expedition with 105k. The plugs had never been changed. I did the seafoam and pm blast method.
Although I still had all but one plug break.
Got the Lisle extractor on order from amazon tonight. It will take a few day to get it here.
so my question is, is there anything I can do while it is sitting in the driveway over the next few days that will make the extraction easier?
Lostneye
NY
Some of the chain parts stores may rent them if you don't want to wait. Other than that not much you can do.
If you haven't already I recommend buying replacement COP boots/connectors not using the originals.
docraymund
philippines
You could soak them in WD 40 to help in the extraction and remove all items that are in the way so you could have more room to maneuver.
tsingson
NC
What Stamp said. That tool is going to blow your mind with how it works.
J
jontanner
Charleston
Update....
I was able to get them all out with the Lisle tool.....that thing is great btw.
Now it is throwing three random misfire codes and left bank running lean code....
I replaced the coil packs, boots and plugs so I am stumped on the misfires.
Engine is running absolutely horrible. Has a bad hunting/surge when it goes over 2k rpms.. also right side CAT is glowing cherry red after ten minutes....
Been turning wrenches on this truck for over a week after work trouble shooting it....
Gonna accept that this repair is beyond my skill set and drop it off at a shop.
Lostneye
NY
What are the actual codes you are now getting? The cat is glowing due to the misfires. I would not run it long like this or you risk killing the cat.
bnicov
Ontario
You may have plugged the right side cat. Does it have any power or is it sluggish. A plugged cat wreaks havoc with an engine causing all sorts of weird things to go on.
J
jontanner
Charleston
After all that work....two of the new plugs were defective. Got it running smoothly again.
Bad news....got to replace the cat now. Guess the few miles I drove trying to test drive was enough to to melt it....
