97 expo dont run right
Racenut
Deming, New Mexico
You need to check spark! If the plug is wet with clean gas, then you know that the injectors are working.
Get something like this:
http://www.sears.com/shc/s/p_10153_...21x00003a&ci_src=14110944&ci_sku=00914130000P
Pull a coil out and hook the tool up to it, then plug a regular sparkplug into the end of it and set it on the valve cover for a ground ( or a test lead with aligator clips one to the bottom of the plug and another to a good ground ) DO NOT PULL THE PLUG FROM THE CYLINDAR WHILE DOING THIS then start the truck and see if the tester light pulses. If the tester does light up and pulse, then you know you have spark on that cylindar and if not then you do not have spark. Repeat on all of the passanger side cylindars.
BTW bad o2's will not cut out one bank. The only thing the o2's will do is tell the computer to give more gas or less gas ( injector pulse ) depending on the air/fuel ratio.
S
strokin393
Va
Could I unhook the harness from one of the coilpack and hook a test light up to the ends of each harness to see if its getting power to it? I did take a coil from driver side that works and put it on pass side and it seemed not to work on the pass side, so that's why I'm thinking its not coilpacks and maybe 02 sensor or the harness not getting power or maybe bad ground if that's possible for it to be getting power to driver side and not passenger side.
The guy that hooked the code scanner up said something about an open loop. I don't know what that means.
Thanks for the info
Racenut
Deming, New Mexico
Yeah you should be able to check voltage at the coil conection wich will tell if the coils are getting power. It could be a bad spot in the harness / pinched or broken wires, or a bad ground.
As for "Open Loop" usually that means, is that the truck has not gotten up to operating temp so the computer is still running off of factory defaults that are stored in the computer and not running off the sensors.
Once the computer goes into "Closed Loop" then it is reading all of the sensors such as o2, air temp, mass air, etc. At this point the computer will use the data from these sensors to change the fuel and timing curves.
It is normal for all vehicles when they are first started to run in "open loop" until the computer senses that the motor is up to operating temp. A bad sensor will also keep the computer in "open loop" but you would have a check engine light if this where to occur.
S
strokin393
Va
What do you mean by I have to check engine light to tell? You saying let it run for long time and hook the code scanner up to see again after the temp of motor gets up? I don't think my check engine light works so I guess I'll just have to have the guy come over and hook the scanner up every so often.
S
strokin393
Va
Ok, I pulled the oil cap off and saw steam and condensation on it. I might have a blown headgasket. How hard is it to replace that on pass side?
Racenut
Deming, New Mexico
If you have a sensor that is not working properly when the computer tries to go into "Closed Loop" it will turn on the check engine light and set a code.
It should not take a "long time" to get the motor up to operating temp, but it would probably take a good 15 - 20 min.
Racenut
Deming, New Mexico
Get a compression test done. You would need to do both "Dry" and "Wet". For the "Dry" test all you do is hook up the gauge and perfome the test on each cylinder and write down all the numbers.
Then go thru and perform the test again, but squirt a little bit of oil down the spark plug hole before hooking up the gauge. Perform the test again and write down all of the numbers.
Once you have finished compare the numbers if you see a large difference between the "Dry" and "Wet" numbers on a particular cylindar then you have an issue with the rings.
Have you performed a "Cooling System Leak Down Test"?
The Cooling system leak down test will tell you if you do have a blown head gasket between a cylindar and a water passage in the head.
Have you perfomed a "Cylinder Leak Down Test"?
For this test you hook an adapter to an air hose and force compressed air into the cylinder. This will tell you if you have a bad Intake valve ( you will hear air coming thru the intake), or a bad exhaust valve ( you will hear air coming thru the exhaust ), or bad rings ( you will hear and feel the air coming out of the PCV Valve hole in the valve cover).
How many miles are on the truck?
If the milage is high and you have a difference in the compression test numbers it would be easier and more benificial to pull the motor out and put in new bearings and rings at the same time you are doing the Head Gaskets.
S
strokin393
Va
I'm draining the oil now and I see no water, just black oil. I just don't know. I had a friend tell me I had bad 02's, had someone say head gasket, and so on. I really don't know and don't have many tools here to do them test. It backfires when I go to start it after having it running before. I think the pass side not burning the gas.
Racenut
Deming, New Mexico
All of those tools can be rented cheaply at your local parts store. If you have any questions about the condition of the motor those tests will let you know if there is anything MECHANICLY wrong with your truck, or if it is all electrical.
Just trying to guess at what the problem is, is really just a waste of money and time sice you do not really have anything to go on!
If you want to figure out what is wrong with your truck, then you need to do the above tests and rule out mechanical. Sice you are saying that there are no codes in the computer then that tells me it may be a mechanical problem.
BTW regarding the black oil, you can still have a head gasket that is blown between 2 cylinders and with that you will not see any water in the oil. Also if it is not a bad leak in the head gasket sometimes it can "blow" all the water from the cylinder out the exhaust.
S
strokin393
Va
I see oily gas or something in the pass side exhaust. I guess I'll get someone to do a comp test for me one dy then maybe give up and sell the truck. Thanks for your help. I'll post back later
S
strokin393
Va
If I were to do a leak down test, what would I set the gauge to and do I put motor on tdc?
Racenut
Deming, New Mexico
Yes you would need to put the motor on TDC of the compression stroke for every cylinder that you are testing that way you know that all of the valves are in the "closed" position.
As far as pressure, I have always used between 90 - 100 psi. Fill it up shut off the air supply and see how long it takes to drop and if it is droping quickly then try and listen to your intake, exhaust, and pcv port to see where the air is coming from ( if the leak is bad enough you may need to turn on the air supply and let it run till you can find where the air is going ).
**Note** With the pressure from this test you may need to have someone holding the harmonic balancer bolt with a socket ( the same one you use to put the motor at TDC for each cylinder ) to keep the motor from turning. As the bearings / rings get old ( high milage ) the force of the air can be enough to "turn over" the motor.
S
strokin393
Va
Ok, when I go to do the compression test, do I start the truck or just turn it over? Can you give me step by step please? Thanks
Racenut
Deming, New Mexico
Here is a good video of How to do a Cylinder Compression Test - For the Expedition instead of trying to disable all of the coils, just pull the fuel pump fuse/relay that way you are not filling the cylinders with gasoline ( and this way it wont start ) also while you are cranking the engine over make sure you hold the gas pedal to the floor so that the engine can pull in it's maximum amount of air.
http://www.youtube.com/watch?v=X_tbksFYhl4&feature=related
And here is a good one for the Cylinder Leak Down Test - It is pretty long at 27 min, but it has all of the information that you will need.
http://www.youtube.com/user/EricTheCarGuy#p/u/23/WgrfT0LFMhc
Hope this helps out a bit! By using these two tests you should be able to find out exactly what the problem is if it is a mechanical problem.
S
strokin393
Va
So, do I take all 8 plugs out or just the 4 on the side that I want to test and how do I test the coil packs with a volt meter? Thanks
Racenut
Deming, New Mexico
S
strokin393
Va
Just wondering if the pass side harness to the coils could be bad, not work but the driver side work if pass side don't? I don't have a way to test and see because I can't keep truck running and its just me here. Like I said b4, I had it running and it wasn't running good so I unhooked the injectors 1 by 1 to see what was going on and the whole pass side made no dif.
If I were to try and test it with a volt meter, does engine need to be running?
If I were to use a test light, the engine needs to be running, right?
I'm just trying to figure out the est and easiest way to find out if my coil packs are getting power to them before I go out buying tools and stuff. I ordered a coil tester, but it hasn't got here and I don't want to wait any loner. I thought it would only take 3 days to get here and I really didn't want to wait that long.
A friend of mine is letting me use his compression tester, so do I cut fuel off while doing this and how? Thanks for all the help
I'm sorry if I'm asking the same questions over, I'm just not thinking straight and this stuff is getting to me, I just want to get this truck fixed.
Racenut
Deming, New Mexico
You should be able to test the coils wiring harness with a volt meter or test light WITHOUT the vehicle running. With the key on you should have a constant 12v + the way the coils work is the computer will " pulse " the ground side of the coil to get the field to colapse causing the spark.
As far as the compression test goes. In order to shut off you fuel supply, just pull out the fuel pump RELAY from the UNDER HOOD FUSE JUNCTION BOX. This will keep the engine from starting.
S
strokin393
Va
Ok, I see that I'm getting power to that side of plug, now how do I test to see if I'm getting the pulse?
