IMINYOURCHAIR
Hi, as the title states, I want to have my radio power delayed as the windows are when the key is removed. Looking at the service book, I should be able to run a wire from the acc delay relay (or splice into it at the harness near the door) and run that wire to the blk/pnk wire (the one that tells the radio to turn on) and have it work that way, the only issue I worry about is that back feeding into something else, so, I may put a 2.5 amp fuse inline before I commit to safe guard the circuit.
has this been done before? also, Is the behavior of mine not normal? ex: when I go from run to off, the windows still work and the int lights do not come on and the radio goes off. any other car I've had the radio and windows still work and the interior lights come on when the key is removed.
