dschallmo98expo
Looking to change out the front spindles on my 98 Expo. Reason..... if you warp the rotors you have to replace the whole wheel bearings and rotor as a combo. Plus they are more expensive.
If I change the spindles from a 2001 were the rotors are like the rear, then it becomes more cost effective to swap rotors or replace without having to do wheel bearings as well.
Does this make sense and can it be done?
opps forgot its 2wd not 4wd
