99 expy front wheel bearings
trippn01
toledo
hey all,never asked for help,but got quote a rescue going on here....did the tie rod ends,idler arm,pitman arm...now its time for front bearings....any clues?tips?tricks?...never done them b4 but really handy with a wrench....thanks in advance
panda24619
San Diego
well is it 2wd or 4wd? cause the wheel bearings are different i think. idk. i never have done 4wd bearing b4. but the 2wd should be easy to do. but which one do you have?
KWT2000
NINE MILE FALLS
remove tire, brake caliper and rotor, axel nut, dust sheild, the three wheel bearing bolts and tap it out or use a slide hammer to remove hub bearing assembly
