ABS Bleeding / Master cylinder question(s)
stangyog
pa
I have an issue with my 2001 Exp. The brake pedal verrrrryyyyyy ssssllllloooowwwwwlllllyyyyy travels to the floor when applied and the brakes fade off. It stops fine, but when sitting at a stop light, after about 10-15 seconds of keeping pressure on the pedal, you can feel the brakes slowly release and more pedal pressure is needed to keep stopped. There is NO FLUID leaking anywhere I can see or feel, and there is no change in fluid level in the reservoir. Just to be clear, it takes probably a good minute of keeping firm pressure on the pedal to get it to go to the floor. Done some research and I think that the master cylinder needs replaced. After I do this, how do I bleed the ABS module? I have heard that I need to take it to a garage and have them use a scan tool to do it. Are there any methods for an above average driveway mechanic to do it.
Thanks for any advise and help that is given!
reece146
ON, Canada
Note familiar with the Ford system but all other cars I've owned (race cars) all it's taken is a few repeated hard stops to self bleed the ABS system.
