ABS light comes on 2008 Eddie Bauer
brad20008eb
Coaldale, Alberta
My abs brakes come on when I start driving and go to brake. The brakes pulse very quickly. After driving up to around 30 the ABS light comes on. This disables the pulse braking. Diagnostics reveal right brake sensor but sensor is working and has been replaced. Has anyone else had this problem. The speeds coming from the sensors is perfect, yet it says there is a communication error with front right sensor. Tire wear is all even. There is only slight play in the hub which
Ford says is normal. I suspect something is wrong with the PCS which then talks to the Stability Control Center. Any advice would be appreciated.
FordCustSrvc
Dearborn, MI
I’m sorry to hear that you’re having this issue, and I would like to reach out to lend a hand. So I can do this, please send me a private message with your VIN, approximate mileage, and dealer name.
Cory
