1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
AC compressor burn out #3
Discussion in '3rd Gen - 2007 - 2017' started by DFendersExpy, Jun 29, 2020 at 8:40 PM.
  1. DFendersExpy
    DFendersExpy Full Access Members
    214
    37
    Aug 17, 2013
    Norwalk , CT
    Ok this is my issue. My Ac compressor started to burn and then completely shut down. My mechanic replaced it along with a valve. It wasent as cold as before. Well the new compressor burned out , the mechanic replaced again along with the condenser and air dryer since he mentioned there was metal filings . Well guess what on a long drive down to Fl the damm compressor burned out again. So now my truck is in GA and have no damm clue what’s causing this issue. Any ideas?????
  2. Retiredusps
    Retiredusps Full Access Members
    71
    58
    31
    Oct 28, 2018
    N.J.
    The system needs to be Flushed.to remove any particals of the old compressor and any other junk.
    DFendersExpy likes this.
  3. 07navi
    07navi Full Access Members
    76
    1,154
    244
    Feb 3, 2020
    Mt.Shasta California
    I there were filings in it I would flush it. It's not an air drier. Year, miles ?
  4. DFendersExpy
    214
    37
    Aug 17, 2013
    Norwalk , CT
    It’s a 2011. Miles are 140k
    The filter black tube he pulled out he called it the drier said it was clogged with metal. Something is causing it, it runs fine for a few days then begin to burn out and stop working.
  5. DFendersExpy
    214
    37
    Aug 17, 2013
    Norwalk , CT
    My concern will it make it back to CT From GA
  6. DFendersExpy
    214
    37
    Aug 17, 2013
    Norwalk , CT
  7. 07navi
    76
    1,154
    244
    Feb 3, 2020
    If there is metal it the drier there is metal elsewhere also, it sounds like it needs to be flushed.
  8. Retiredusps
    71
    58
    31
    Oct 28, 2018
    N.J.
    Your Mechanic should have flushed the system, Even instructions with a rebuilt states no warranty unless system is flushed. I would get a NEW mechanic !!! after 2 compressors must be alot of crap in system. Maybe he never added oil to the system or wrong oil.
    DFendersExpy and 07navi like this.
  9. 07navi
    76
    1,154
    244
    Feb 3, 2020
    Right, it could be an oil issue, I didn't think of that. They need oil to run right.
  10. DFendersExpy
    214
    37
    Aug 17, 2013
    Norwalk , CT
    This sucks major moose egg!!! I gotta find a mechanic in GA now.... I'll hate to drive back to CT without AC...
Share This Page
