ac sucks at idle
Jdm5630
texas
Ive noticed the ac only blows warmer air at stop lights or when its idle. I can leave it idleing and it will never cool down. What gives i know it shouldnt be that bad.
Copper93
Charlotte, NC
It may be a little low on freon. I know r134 doesn't cool as well as the old r12. I can feel a difference in mine at idle and moving but it will still cool.
Temple, Georgia
First step in a/c diagnostics is to determine what the low and high side pressures are or at least the low side pressure. Once that is known they will point you towards the next step. You may have a system that is low on refrigerant or a fan clutch that is inoperable. Without knowing the pressures you could end up tossing parts at it until you get it.
04SVT
tx
^^^agreed. Sounds like it could be a compressor on its way out, buts that's cart before the horse. Get the pressures and it will tell a lot
J
Jdm5630
texas
How do i check the presures? I did notice that with it in i can cool air in the front the the rear blows warm air.
Temple, Georgia
You'll need a set of a/c gauges for r134a refrigerant. If your not going to fix it yourself then getting a set of gauges isn't a good investment. Usually you can get the basic tools for less than the cost of having it fixed. There are plenty of online sites that sell the tools needed, one that I use is Tooltopia.com
Take a look at their a/c tool sets and determine if it is something you want to get into. I'm guessing but I would expect to spend around $600 for the vac pump, gauge set and can tap & possibly a dye set also. If you buy the r134a in the 30lb bottles it is considerably cheaper per ounce than the individual cans per ounce. The last bottle I bought was right at $100.
04SVT
tx
If you buy a 30# you won't need the can tap but you will want to watch how much you put in. I usually pull a vacuum on the system and charge the whole system by weight.
04SVT
tx
These are very sensitive to pressure. They aren't like a home unit that can function alright with a little excess pressure.
metaldrgn
somewhere
You can rent the gauges and pump from autozone and they give you all your money back.
If your year has an electric aux fan I would check to see if it's turning on. It should turn on as soon as you turn on the ac. If it doesn't have that I would check to see if the compressor is cycling at idle. If not have someone rev up the engine to 1000 then 2000 rpms and let us know if it's cycling and when.
Like stamp said, check the high and low side pressures with the gauges.
tonydiv
technical advisor
Middle River, MD
Could also be the condenser. If it's gunked up with debris, it won't let enough air pass over it to work properly at idle. When you're driving, and forcing air over it, it will work a bit better.
Other than topping it up with a can of AC Pro, there isn't really that much you can do (legally) without the proper equipment.
Your best bet may be to just take it to a certified professional.
J
Jdm5630
texas
Im goin to try cleaning the condensor. Do i just spray it with water?
04SVT
tx
Spray it from the engine bay out....if you spray from the front it will compact the cap into the condenser
Mangina
calgary, alberta
I'm going to go against the crowd and say it's pretty normal for it to cool less at idle. Every vehicle I've had is like this including my 13 Expedition.
Maybe yours is worse than normal?
