Air Suspension Bypass
tx_roadkill
El Paso
I have a 00 EB Expy and I changed out the air to coils and now I have that pesky alarm. I cut the wire for the light so I no longer have that, but that beeping is quite annoying.
Can someone please help me in remedy this issue?
Thanks in advance!
doodlebugs-93
hello, my name is Patrick, this might help you out, after you changed out the air suspension to coils,did you flip the air suspension switch to the off position? I'm in the process of getting my air suspension changed over to coils on all four corners, once I'm finished doing that there's two switches under the passenger side of the dash one for the fuel pump reset and the other if for the air suspension shut off good luck and let me know how things turned out.
