yep...Exporer it is, still seems like a lot of work just to get an alternator out. You should see what the OEM's have done with the starters on the new semi's. Suckers are stuck inside the frame rail on some of them. All in the name of mpg....
Exploder below:
Service Manual: CHARGING SYSTEM Print Date: 4/28/2019
2012 Ford Explorer 3.5L Eng VIN 8 Base
REMOVAL AND INSTALLATION > GENERATOR - 3.5L TI-VCT > REMOVAL
1. NOTE: The radial arm adapter is a serviceable item. Do not replace the generator if the radial arm adapter is the only concern.
Disconnect the battery. REFER to BATTERY DISCONNECT .
2. Remove the cooling fan motor and shroud. REFER to COOLING FAN MOTOR AND SHROUD - 3.5L TI-VCT .
3. Rotate the accessory drive belt tensioner clockwise and position the accessory drive belt aside.
4. Position the generator B+ terminal protective cover aside, remove the nut and position the generator B+ terminal aside. To install, tighten to 17 Nm (150 lb-in).
5. Disconnect the generator electrical connector.
6. Remove the RH fender splash shield. REFER to FENDER SPLASH SHIELD .
7. Fully loosen the generator bolt. To install, tighten to 47 Nm (35 lb-ft).
8. Remove the generator stud nut. To install, tighten to 47 Nm (35 lb-ft).
9. Remove the generator stud and the generator. To install, tighten to 8 Nm (71 lb-in).
