Amp fuse/breaker
Bigswoosh
Las Vegas
So I installed an amp and sub in my 97 XLT. I used one of those amp installation kits which had a 60A fuse. So I installed the fuse and after starting the engine several times.I noticed that the fuse was burned already when my amp didn’t turn on. I saw a 60A breaker on Amazon for like $10 so I thought maybe I should put that on to protect the amp. It pops almost every time I start her up. My amp seems to be fine. It has a 30A fuse built in. I’m just curious why it keeps popping. Should I keep the breaker? Any suggestions?
1970Maverick
orlando, fl
do you have a drawing of how you wired the amp, fuse, etc. Without that information it's near impossible to troubleshoot or make any suggestions for a fix.
B
Bigswoosh
Las Vegas
I don’t have a drawing. I put the breaker in between the battery and the amp. I used the red 8 gauge wire that came in the kit that was labeled for power. Does this help at all?
1970Maverick
orlando, fl
That doesn't help me understand how it's wired. can you make a wiring sketch? What doesn't make sense is that the 60 amp fuse is blowing before the 30 amp fuse that you say is built in to the amplifier. That's why a sketch would be helpful. I made my living troubleshooting electrical/electronic circuits and without a diagram it's near impossible to know how the components are tied together.
