Android auto problem
T
Timmaaay4
Just a update while driving the other day Android auto was working then got a call and it disconnected. Was not able to connect again or charge. I did the power and skip button to reset that didn't work. Also preformed a master reset of sync which wiped the settings still nothing. I did some digging around some other ford forums about the usb hub and came across some that had gotten moisture in them causing them to short out. I took a gamble and ordered the attached part. A quick 5 min install and it worked. f3b6b70e6d26ec442edcfaf31b7f005c.jpg
Sent from my SM-G970U using Tapatalk
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Nice!
T
Timmaaay4
The part was out of stock most places found a seller on ebay and gambled. There seem to be a couple different models but there was a specific one for the expeditions
Bodacious
SC
Timmaaay4, I just bought a 2018 Limited and having the same issue with intermittent phone disconnect/reconnect from the hub. Just saw this thread as I had started one yesterday and came up with the same hub part number. Will be ordering this week and install as soon as mine gets out the shop for a rear suspension issue of some sort. Yes three weeks in and already enjoying early failure of some sort (otherwise love the Expy). Please update if issue continues. Thx!
Was the USB hub difficult to remove?
T
Timmaaay4
Pro tip for removal of the hub I found in a f150 forum was to use a paint can opener, to remove the hub. There is a notch/push pin area on the top an bottom. But it is quick and easy 5-10 minute job.
T
Timmaaay4
No idea I was trying to determine if the other main model would have worked also. I wouldn't think that there is that much difference.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Any idea if the USB C/USB A combo version can be installed instead? And P/N?
It can if it is like the 16-17 Expedition or the 16-20 Edge. I did it in both as have many others. Remember the USB C does no different voltage or speed, just gives the cable option.
MxRacer965
Hudsonville, MI
That’s fine. I just would like the option to plug in USB C. Like many I have increasingly started getting a mix of stuff...so I’d like to have a mix in the vehicle.
anyone got the P/N handy? What about the USB ports for the 2nd row in the console?
Dcleghorn01
