Another Timing Job Question -2003 5.4L 2V
acampinoob
Richmond, Virginia
So I've been doing my research and have decided to take on the front timing job in spring. I've watched Makuloco's videos and have been lurking around the forums. A few questions still remain for me. What sort of special tools will I need? I see there is a 303-102 Crankshaft Damper Installer and 303-335 Front Cover Oil Seal Installer. Those are the ones I haven't been able to source reasonably. O'Reilly has a 67006 rental for the damper installer, but there is questions regarding whether it works or not (as @whtbronco mentioned in his post). I was able to source the PS Pump Pulley Remover, Crankshaft Damper Remover, and Engine Timing Kit from Amazon. Is there anything else I should need? I plan on dropping two of the bolts from the front diff to swing it out of the way to get the pan off, so the flex head ratchet isn't needed for the oil pump pickup tube. I also plan to remove the radiator for access too.
Another question. While I have the pan off, should I do rod and main bearings? I have 180k and a little chain slap. My hesitancy is that they are TTY bolts that may be tough to source, especially since there are side main bolts too. I'd appreciate the knowledge @whtbronco and @Hamfisted . You guys are my heroes lol
I also have a SMALL external coolant leak originating from the driver's side head gasket leaking into the valley. I've already done the intake with the ford part and the crossover tube orings and can visually verify it's the head. I plan on pulling heads and have them sent off for reconditioning (new seals & valve job). I can get all lash adjusters for like $85. Is it worth doing as I'll have the heads off? I'd like to get at least 300k out of this motor and with the melling timing kit and high volume oil pump, I think I could make it... Only thing I don't really want to do is piston rings and deglaze the cylinders. That's too far haha. I feel like this can all be done for less than $2k including the machine work (I was quoted $500 total).
whtbronco
Winchester, VA
If the coolant hoses are original as mine were this is a great time to replace them.
Honestly the only way to know about the main and rod bearings is to judge the wear you see on the heads and timing chain parts. From that decide if you want to pull a cap from the crank to check. If I was to replace the main and rod bearings there's a good chance I'd take a look at ARP for replacement bolts. I'm not a big fan of TTY bolts. Though the cost of ARP at times sends me back to replacement TTY bolts. I gotta say if you get the heads rebuilt and replace the crank and rod bearings I would without question hone the cylinders and replace the piston rings. I mean heck you'd have darn near a new engine.
The bolts look to be readily available which is good news, but dang they are costly bolts.
Ford F65Z-6345-AA Engine Crankshaft Main Bearing Cap Bolt
Ford F3LY-6214-A Engine Connecting Rod Bolt
Probably no need for the 8mm flex head ratchet wrench if you are gonna pull the oil pan. A deep well 8mm is what I used for the valve covers, along with wobble extensions. A 10mm flex head ratchet wrench helped me with removing the power steering pump.
Unless the timing kit you're getting comes with it you'll need some RTV for the timing cover and valve cover install. New valve cover gaskets, I'd go with Ford replacements since my Fel-Pro passenger side didn't fit.
I ended up going with the standard volume Melling oil pump. I couldn't justify the higher volume this time. I'm not sure either is a bad choice though and I have used Melling high volume oil pumps in the past with good results.
Pretty sure I used the 67306 harmonic balancer installer rented from O'Reilly.
The camshaft holding tools are nice to have, the idea of using vice-grips did not sit well with me. I used a ratchet and extension to turn the cams though and the crank alignment tool I bought was a worthless POS.
whtbronco
Winchester, VA
Nah, I used the trash below from Orion Motor Tools. At least the crank alignment tool and the valve spring compressor were trash. The cam holding fixtures, but they ended up working fine. I won't buy these cheap tools again. I know better, but I didn't listen to myself, again. In this case I knew there was an alternative alignment technique so I could get by without the crank alignment fixture. Heck I could have removed all the rocker arms and gotten away without the cam holders too.
Vincent Vega
Huntington Beach, CA
Been a few years since I did the timing on mine, but to answer some of your questions, I did not need to use a special tool to replace the front main seal. And yes, definitely worth replacing all lash adjusters and rocker arms while the heads are off. It is alot more difficult to replace the rocks arms with the heads on. One other thought is that its about the same amount of work to replace the head gaskets as it is for a new engine. Also, consider getting the Melling timing kit; you won't want to do this job twice! Have fun.
scoot0073
Georgia
I have 319,000 MI on on my 03 Expedition Expedition 5.4 2v 4x4
I did my Timing Chain replacement about 5 years ago.
I did upgrade the chain tensioners to the cast iron set. As the new timing set came with plastic like tensioners.
I also replaced the oil pump but didn't have to drop the oil pan.
The power steering pump I just unbolted it instead of using the pulley puller.
I did both valve cover gaskets they wasn't any signs of leakage but I figured might as well replace them also while everything is taking apart.
Original motor and transmission.
Fastcar
Army
FL
I'm curious how this job turned out. Especially the R&R of the main and rod bearings.
A
acampinoob
Richmond, Virginia
I'm waiting on nice weather. Here in VA we just had an ice storm so I'll get started mid March. I'll update this thread with pictures regardless of how it goes!
whtbronco
Winchester, VA
A couple other things that might help with the timing job. Start soaking the EGR stove pipe connections with penetrating oil when practical. Take pics of the vacuum and coolant hose and wire harness routing before you start.
You do not need to remove the water pump, but if you haven't done this before I think it's easier. Certainly was for me, it's just 1 less thing to work around.
kep5niner
Army
MO
Engine swap $3k, with a 3 year / 100k mile warranty. I did the work. Worth every penny. I’ve got some threads on here from a couple years back with many more details. Part of my complete restoration of an ‘03 EB.
A
acampinoob
Richmond, Virginia
51711.jpg These were two rod main bearings I pulled. For an engine with 175k, I'm honestly going to leave the rest of the bearings alone. There is more risk of introducing dirt since I'm doing this in chassis than replacing bearings in excellent shape. With the high pressure pump and Amsoil, I should be good for at least another 100k, bearing-wise.
I have the Virginia Pollen Apocalypse coming, so pan is back on for now and I'll be jumping into the top end soon.
A
acampinoob
Richmond, Virginia
Everything is all done and things went great. Note to others doing this. DO NOT BUY THE TIMING TOOLS. They are completely unnecessary. Disregard the timing instruction from the manual and just keep the crank with the keyway at 12 o'clock the entire time. At this position all the pistons are way below deck and there is no risk to the valve train. Just align your timing marks and you're good to go. The only thing I used the timing kit for was the cam turning tool, but that's only because I had it. Otherwise it could have been turned with vise grips between the cam lobes.
Another note I wasn't aware of. I opted to replace the power steering pump while I was in there, and Ford uses quick connect fittings for the pressure side at the pump. There is literally NO WAY to disconnect the line from the fitting once installed. The Ford procedure recommends using a special tool to install a new teflon seal on the fitting, and aint nobody doing that when the fitting is $2. It's also a bear to get to and I'd be pissed if I had a leaking seal. I ended up doing a new rack & pinion and all new lines and fittings, so it wasn't a problem, but I feel like this is not general knowledge. I now know my they recommend pulling the pulley when doing a timing kit.
