Auto Shut Off
Mike J5
Springville, NY
I have a 2020 Expedition and all of a sudden, my auto shut off is not working. What might have happened to cause this?
GixxerJasen
DFW TX
Yup, check the status, if it says due to charging, then a new battery should be in your near future. Mine is doing this and the other telltale signs, I figure mine will last through the summer and I'll replace it before winter.
lobsenza
Try trickle charing your battery monthly. It really helps with battery life and allows auto stop/start to work.
2020FordRaptor
Nevada
Plus if it over around 80 degrees, or you have the air blasting, etc. it wont shut off.
California
Mt 2019 Limited started doing this as well. I don't drive the vehicle enough. I purchased it brand new and around three years later it only has around 16k miles, which probably decreased the battery life. Still, surprised to see a brand new OEM battery to begin to fail so quickly.
LazSlate
Arizona
Auto Start is so ridiculously stupid. It will destroy your battery. A Lead Acid battery is designed for high CCA starting and does not have the Reserve Capacity of a Deep Cycle Battery. So constantly asking the Battery to deliver these AMP spikes all day and they try to recharge is a good way to kill the battery. When the car shuts of and the accessories are running, even headlights at night, a non Deep Cycle battery does not like that RC kind of load.
Auto start was probably invented by the Service Department to crank up the billable hours of the Turbo Encabulator.
Bmac1955
Southern Cali
Original battery in my 2019. Just replaced it this month 4/2023. Limped it along with an agm charger. Was losing accessories and decided it was time. 4 1/2 years and 40k decided it was time to replace with OEM battery. Put it on my agm charger to top it off.
Goff69
