Oil Catch Can in Cold Climates
LokiWolf
Super Moderator
Super Moderator
Richmond VA
LokiWolf. Thanks so much for your response. Most of us DIY hacks really appreciate your wisdom on this platform.
Regarding my drain lines for my RXP dual cannister setup, I dropped one line from each of the two cannisters and brought them into the driver side front wheel well and put on two ball valves. I think they were 3/8". I had to adjust one of the ball valves a little higher after initial install due to a slight wheel rub. Makes it real easy to drain the stuff in the cans. I just do it with each oil change. Without this setup, it is a royal PITA to drain the cannisters the way they are set up to be mounted by the manufacturer.
Glad to help! That is an amazing mod to the RXP kit, and for the money they should come that way. That negates the tucked location problem! Great job.
