Axle spline count question for running a Truetrac or locker
Kryo-Genik
El Paso TX
Wanting to Detroit Truetracs front and rear on my 03 EB...unless someone can convince me to run A Truetrac up front and a locker in the rear. My expy is daily driven, sees road trips with the family, goes off road and hits back trails, I'm not climbing.and crawling huge rocks and shit here so I dont know if a locker is needed....but I'm open to being convinced otherwise
Anyways just to make 100% sure our axles are as follows
Front 8.8in IFS with 28 spline axles
Rear 9.75in IRS with 34 spline axles
Which means only the Detroit Truetrac for the front is this model
https://www.eaton.com/us/en-us/skuPage.912A563.html
And our rear unit would be this one
https://www.eaton.com/us/en-us/skuPage.913A477.html
And if you can convince me to run a locker in a daily driven expy....the locker for our rear is this one
https://www.eaton.com/us/en-us/skuPage.225C194A.html
Is this all correct or am I missing something somewhere?
Kryo-Genik
Kryo-Genik
El Paso TX
Have you called and verified if this will fit the front diff? I called about putting one in my 2002 F150 in the front and they said it would not fit the front housing.
I'll need to call.but from what I'm seeing it will work for me. You being an 02 ...I'm not 100% but I think your axles are different than mine.
bsutton1705
Arkansas
My expedition is a 2003 but I think the front diffs are the same on the 99-03 F150s and the expeditions up to 2006.
Let me know what you find out beccause I wouldnt mind to have one also.
creecer
Woodstock, GA
The front locker will help much more than the rear, and you won't really seen any driveability issues on the street.
OverlandExpy
Northern California
Kryo, what did you end up doing? Trying to make the same decision for my 04 EB at the moment.
PaulMedik
