I have a 2002 Eddie Bauer and I have been having trouble with the battery continually draining. Replaced battery and it still happens. It takes about a week to drain completely.
So far here is what I have done. Positive battery cable connected. Negative cable disconnected with volt meter between negative terminal and cable end I am reading 12.85 volts. Disconnected alternator, voltage didn't drop. Disconnected all fuses and relays, voltage didn't drop. Disconnected wire from starter solenoid to main under hood fuse box and voltage dropped to "0". Is this supposed to have voltage to it all the time and if so why is it reading through the negative cable? Also, I cannot get any type of amperage reading, just voltage. Any ideas?
So now I will put it all back together and try again tomorrow. If anyone has any input as to what my be causing the drain please let me know. Thanks!
