What options are there for transmission temp monitoring while towing?
2010 EL Limited Towing a 30'Bunkhouse.
Simple hardwire?
Programmer?
Something that fits on the A pillar like on a diesel?
We tow a bit and I just want to make sure i'm not pushing it too hard, or to see a problem starting before it leaves me stranded. The towing setup works great, just want more. I would like to be able to have it "mounted" like the edge programmers had that housing for the F150. If I can re-calibrate for a different tire, or if there was a decent tune I would look into tuners, though I don't want to run premium fuel. I have run mid-grade when towing. Didn't see much of an increase in power, though I did see a decrease in fuel economy.
I guess if I had a code hit while towing I could also look at it if I got a programmer.
Like the stupid wrench icon that hit when I first started towing, found it was more me and my throttle build in to the hills than any actual issue with the transmission.
Thanks for thoughts and input.
Also if i use the OBD-II port for the programmer than it can't be used if I want to add the Smart Link option Ford is coming out with right? So it there another option, or will the smart link tell me everthing i want to know
Matt.
Simple hardwire?
Programmer?
Matt.
