Bg oil treatment
nikolas724
new york
Hi everyone, I have a 2007 Ford Expedition and the last owner didn’t really keep up with the oil changes so it’s a little sludged up. Could I use bg oil treatment or would that cause more damage? The truck has 117,000 miles.
makenzie71
Tx
I wouldn't. Oil treatments, seafoam, most of that stuff is snakewater. Best thing you can do to address previously conducted regular maintenance is to start performing regular maintenance.
99WhiteC5Coupe
I would not use any oil treatment.
I would change the oil and filter, using synthetic oil (not synthetic blend or convential oil), and a Motorcraft (or very high quality) oil filter.
Synthetic oil has high cleaning ability and may help clean-up the sludge. After the change, you may want to change it again in 3,000 miles - including the filter, as it may get partially clogged from the cleaning.
Fastcar
FL
There is no such thing as a mechanic in a can.
Timo2824
Wichita
I've seen videos of seafoam cleaning sludge up enough to stop lifter clatter. Just know that sludge in the heads can break off and possibly clog an oil gallery that feeds a bearing.
