Bilstein Rear shock setting?
X BRONCO OWNER
US
Im getting ready to install rear Bilsteins and was thinking about moving the snap ring up a notch or 2. I think the truck sits a bit low in the back from the factory. Has anyone done this on an otherwise stock truck. Im concerned it might make the ride harsh. Thanks
X
X BRONCO OWNER
US
So I got the new shocks installed I set the c clip to the second notch which according to Bilstein gives it a .4 inch lift. The truck feels so mich better no more bouncing over bumps and feels much more stable on the highway. The only thing I noticed is that my drivers side ride hight is about a 1/2 inch higher then the passenger side. I wish i measured the ride height before installing them. Does anyone know if the drivers side rear should be slightly higher?
wakeboarder
Fort Lauderdale, FL
Upside down spring perch on one side? See linked thread.
X
X BRONCO OWNER
US
The spring perch is good on both sides. I marked everything with paint to make sure the springs were going back in the same position as well. My driveway is not 100% level so my next step it to take it somewhere else and measure again. I also checked with a 1/4 tank vs full tank of fuel and was still off by 1/2 inch
