joethefordguy
True but Bilstein is kind enough to provide new hardware so no need for the extra step.
An update on my venture I ended up going with the adjustable Bilstein 5100 instead of the 4600 with a spacer.
The top notch for the 5100 equates to a 2” lift on the F150s. With the different spring between the Expedition and F150 it equates to a 4” lift on the Expedition.
Needless to say that is way too much lift on the rest of the stock components and really can feel it being over extended on larger bumps.
So I will be pulling the fronts and dropping the snap ring down 2 notches and hopefully be at 2”
Black, assuming you adjusted the Bilstein for a 2" lift, is that 2 inches with or without a 3" front spacer lift on the top of the strut mount?
thanks for your time.
jg
