Michael Porchia
Hello, was looking for some advice..
I have a 2007 Eddie Bauer with the following issues. Brake interlock preventing moving shifter out of park, no brake lights, and remote start does not shut truck off when you step on brake with key off. I suspected the brake light switch, so bought a new one at advanced auto and replaced it. Same issues. Tested new switch for continuity between pin 1 and 4, moved plunger in and out, nothing. Thought new switch must be bad, got one from Ford, same issues, test on switch for continuity, same result, nothing. When I jump the connector from 1 to 4, brake lights work. Have power to switch from fuse. Like to add, when I test the contacts in brake switch that are normally closed (pins 2 to 3), they never open when moving plunger. I now have three switches, all test the same, not sure what I’m missing here. Any help appreciated.
Thanks
Thanks
