Well I have had this problem since winter and it seems to be getting worse as of late. My ABS light popped up in the middle of winter and has not gone away
At first I thought the pulsating was the brakes up front that were in pitiful condition, and I replaced the pads and rotors on both sides.
Shortly after I had to replace the master cylinder to abs module brake line, but I did not bleed the brakes.
I also did the mod on f150 online where you turn a bolt inside of the master cylinder that is supposed to remove the slack from the brake pedal
To me this problem is either the ABS sensor, where ever that is, the after effects of the mod, or too much air in the lines, any suggestions?
