Buy Engine Coolant Through Ford Pass?
Shotgun76
Suburban Chicago
I thought I recall seeing a thread where someone recommended Motocraft engine coolant, purchased through Ford Pass. Went to look for it and it doesn't seem to come up in Ford Pass. Anyone have any info? Might just be user error on my part but I've tried several different searches with no luck.
TIA!
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Well, the coolant itself may be as good as any other NAME brand, but if you could actually order it thru FordPass, it would most likely come from the local stealership's stock, or the warehouse where they get their parts from, and therefore would be probably be considerably more expensive, as is almost everything purchased from those locations.....
IIRC, name-brand coolant (Zerex, Prestone, Peak) usually runs ~$11-19 per gallon for the pre-diluted DexCool type....
Reminds me of the time my ex-stealership wanted to charge me $68 for a single (incandescent) replacement brake light bulb, plus another $117 labor to install it...... little did they know that I replaced the OEM one with an LED version for about $13 from da Zonner, and about 6 mins of work...
They also quoted me $309 to replace the 3rd brake light assembly, which they claimed was bad....which I had also recently replaced with an LED version for $39, also from da Zonner, and about 4 mins of work :D
BMW2FORD
CT
I order it all the time.
Go to Parts.Ford.com and sign in. Pick the dealer but note that prices change drastically dealer by dealer. You can pick it up to save shipping although sometimes that’s required for fluids and pay with ford pass points or a CC card. Just make sure to search for yellow coolant and the pre diluted and concentrate types will come up.
