Cai and led headlight bulbs
Slingblade07
Alabama
Ive been wondering if the 2004-2008 f150 5.4 cai is the same and would work on my 2007 expedition. New to these. I love it and I'm slowly fixing it up. I've got the limited EL. Leveled with 33/1250/20s.
Also what brand led headlight bulbs are you guys running?
2020FordRaptor
Nevada
LED headlights in a halogen housing are a really bad idea. Better off getting a good halogen bulb.
ExplorerTom
Colorado
I subscribed to that thought as well for awhile, but then I bought these:
Now I can actually see at night. I had some new Sylvania Vision Plus bulbs in there before and they were pretty lacking. Nothing like seeing the shadow of your vehicle when someone is behind you with brighter headlights. Not anymore. And while driving 2 lane country roads, the oncoming vehicles aren’t flashing me.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Can you elaborate a little please ?
I only ask cause I am currently using LED's in my 011 EL, which came with Halogens as OEM, nottaproblemo :), and I also use similar versions in my other vehicles too !
Gary Waugh
Princeton, TX
I switched to LED bulbs many years ago (08 expedition) and have never looked back, I adjusted them by parking my car 50 feet from my garage door, measured the height of the center of the headlights from the ground, put a mark at that same height on my garage doors and adjusted the lights so that on main beam, the light was shining on my mark. I have never been flashed and have way more light than the crummy stock halogen bulbs.. I just used LED bulbs from Amazon, they last 5 to 6 years before they burn out..
bloodhound
Merica
Ran these in my 2009 and 2014. They are awesome, don't blind oncoming cars, and last a few years.
BigOleFordFan
Army
Those are the same ones I am using now, however, back when I bought my 1st set, they were only $33 hehehe :)
BlackBetty
Army
Surprise, AZ
LED bulbs in your halogen headlight assembly is fine. Just be sure to “clock” the halogen bulb in the same orientation as the halogen bulb that came out.
This will prevent the light from being shot straight up in a high beam pattern. Make a note which way the halogen build element faces when it’s installed. If you can’t see it move it and see what position it’s in when turned to the locked position. Once you know this information, put the led chip boards in the same position.
For example, if you were to look into my ‘24 Ram headlight assembly the chip boards are facing left/ right. When I had them installed in my ‘16 Expedition they were installed up/ down. People were flashing me at first. Ended up aiming the lights lower. When one of the LED bulbs went out I reinstalled the OEM halogen bulbs. Couldn’t see anything because the headlights were adjusted too low. Made another adjustment.
Watch a Headlight Revolutions video and they explained that you need to put the LED bulb in the headlight the same way the halogen came out. When I did that I got a defined cut-off line projected on the wall.
2020FordRaptor
Nevada
Usually LED bulbs in a halogen housing cause the light to scatter really bad, which will blind oncoming drivers and give you reduced visibility. A good halogen bulb will give you better headlight power and improved visibility of the road ahead.
callwill
WNY
I have led bulbs in the headlight housings of my 2011. The guy i bought it from had put them in wrong. one they were properly "clocked" as stated above, i would never go back to the oem bulb.
Broncoholic
Space Coast, FL
I run Sealight S2S in all 4 of my fam's vehicles (2002 Escape, 2003 Expedition, 2003 Pilot, 2016 Expedition). I ran them in the 2016 for a year before replacing all the others. I use the 6500K bright white and we think they're great.
walshine
Iowa
I too run Sealight LEDs in my 2015 Limited with projector lenses. I originally installed the X1 in low beam and made a huge improvement over factory bulbs. Then a year ago I switched to their X4 series in low beam and HOLY COW! Awesome bright light! Shortly after I upgraded the high beams. I wanted to put in the X4 in high beam as well but they wouldn't fit (couldn't get the rubber dust cover back on). So, Sealight was super helpful in trying different bulbs until we found one that fit which was the X2 series for the high beam. I've only had them in one year, but no problems. I absolutely love them, super bright, clean cut-off line, but correct installation and orientation /bulb position is critical, as mentioned in other posts.
It was very disappointing how lame the factory headlights were!! These LEDs made day/night difference (pun intended).
BigOleFordFan
Army
I don't know about other models, but this is usually due to the LED's being installed incorrectly, as noted by others, and I admit, I did this with the 1st set, but I quickly realized what I had done & fixed it by reorienting the bulbs correctly, nottaproblemo :)
Ok, you are entitled to your opinion, but you will NEVER convince me of this, as I noticed a significant increase in both the power & visibility immediately, even when compared to the top of the line Sylvania & Philips "Ultra" halogens....
ExplorerTom
Colorado
Agreed.
The difference between my new LEDs and old halogens is like having the headlights on vs off.
Wisconsin
I appreciate this and all, but my limited experience is that LED just blows OEM away. Seems like they need to be clocked right as others have said, but if you're using halogen it feels like you are just not seeing the road...
